Possible Sale of Still Spirits Airstill
Rehome your items or tell us what you are looking for.
StillBrewing
Valued Member / Donated to SS
Post by StillBrewing » Thu Jun 13, 2019 4:22 pm
I've got an Airstill which honestly hasn't had much use at all over the few years I have owned it.
From new I'm thinking it has been used no more than ten times, and two of them were quite recently. I have never got on with it so its been stored in a cupboard for most of its life.
Now the bad part. Its nothing serious and certainly doesn't affect its functioning. Firstly its got a slight ding in the outer casing of about 8mm. It also has a very slight depression to the left of the label. These Airstills also have a cut out button on the base. For as long as I can remember this button hasn't worked, not that its caused any problems. It is over to one side and looks like it just needs reseating, an easy job which won't take too long.
So, what's it worth. It works without a problem, just needs a little fettling. Photos are available for those that are interested. I can email them or send them via Facebook.
Moss
Admin & IT Bod
Contact:
Re: Possible Sale of Still Spirits Airstill
Post by Moss » Thu Jun 13, 2019 6:39 pm
You should be able to post photos on the board
Have you tried turning it off and back on again?
Web Developer. Will code for food
StillBrewing
Post by StillBrewing » Thu Jun 13, 2019 6:45 pm
Of course Moss.
Is it still like the old way, uploading to a hosting site first.
Moss
Admin & IT Bod
Contact:
Post by Moss » Thu Jun 13, 2019 8:22 pm
No. I have adjusted settings so you should just be able to upload directly. Give it a try and let me know if you struggle
StillBrewing
Post by StillBrewing » Thu Jun 13, 2019 9:30 pm
For some reason its coming up with an error once I upload the pics through attachments.
''It was not possible to determine the dimensions of the image. Please verify that the URL you entered is correct.''
Status showing a triangle
Post by Mash » Fri Jun 14, 2019 6:30 pm
Does it have an on-off switch beside the power socket and what is the power rating ?
To Gin-finity and beyond !
Moss
Admin & IT Bod
Contact:
Post by Moss » Fri Jun 14, 2019 11:25 pm
Test for uploading images
Moss
Admin & IT Bod
Contact:
Post by Moss » Fri Jun 14, 2019 11:30 pm
@stillBrewing
Try using the attachments tab/add files option under the full editor box to attach your image - it worked for me
StillBrewing
Post by StillBrewing » Fri Jun 14, 2019 11:41 pm
Mash - No on/off switch apart from plugging it in. The power rating is 340W.
StillBrewing
Post by StillBrewing » Fri Jun 14, 2019 11:44 pm
Image adding still not working for me Moss. Tried what you said and also did the same yesterday through the full editor. I can load them on but the status bar turns from a green line to a triangle soon after. It then comes up with the same message I mentioned above.
Post Reply
