Bakers yeast works well for me too and I've been surprised about how well it has done in multi generation washes.
One thing I've recently found helps a lot with all washes in to make a yeast starter where you grow the yeast colony before pitching. This is not the same as re-hydrating a dry yeast.
I make my starters by boiling 2lt of water with a half tsp of Citric acid and 8oz of sugar. Dissolve the sugar and simmer the liquid for 15 minutes. Next, quickly cool the mix, I place the pot in an ice water bath, and whisk with a hand whisk to add air to the liquid. When the liquid temp drops below 30oC pour the liquid into a 3lt jar and add your dried yeast and stir. Leave in a warm place for 18-24 hours in which time the yeast will grow to provide a healthy colony with which to inoculate your wash. This method also negates the need for a lag phase in the wash so the yeast will get right down to the business of making alcohol.
I run 6kg of sugar with a bread yeast starter and now, with the pH problem sorted, my ferments are finishing dry.
I found it important to wait a few days after the ferment is finished before racking the wash off into a clean bucket, leaving the yeast cake behind. If the wash is degassed a couple of times it will clear if the temp is low enough. in recent weeks, because of the hot weather, I've been using a little Sparkolloid but any finings will do the job really, Bentonite is good too if used properly.
For me, learning about using a pH buffer has been the biggest lesson that has produced the most useful results for me in recent times. It really did sort out 90% of the problems I was experiencing with washes.
