Page 1 of 2
Water flow control
Posted:
Mon Feb 27, 2012 12:28 pm
by Admiral Toad
Just in case anyone missed the posts I put on about this ....
At a suggestion fromYHB I bought a
pressure reducing valve with gauge from EBay team supplies for around £20.
Got this plumbed into a branch off sink feed adjusted to about 1 bar
pressure then ran water through needle valve as per normal
very pleased with result hardly any temperature fluctuations much more controllable and you can run washing machines flush loos etc with hardly any effect on outlet temperature
Def worth doing !
Re: Water flow control
Posted:
Mon Feb 27, 2012 7:10 pm
by YHB
Thanks for the credit, no need, I am just glad it lived up to my sales pitch.
In case anyone wants to Google your description to find one, please note that the device is a Pressure Reducing “Valve” not cable.
Toodlepip
Brian
Posted:
Mon Feb 27, 2012 10:07 pm
by Admiral Toad
Bleeding I pad spell checker i'll sort that now cheers mate !
Posted:
Wed Feb 29, 2012 8:28 pm
by Admiral Toad
At the risk of blabbing on and getting boring ...... This
pressure valve is bloody magic! an evening run ( always a bit more stable water
pressure around here) and hardly a degree temp variation you can waddle off have tea, watch the telly even make love to the wife ( sorry forgot could do that before only 2 mins away from still)
Oh yes......! best investment so far
>:D
Posted:
Wed Feb 29, 2012 9:12 pm
by MrCat
Tempted to buy two of those, hook them up with two taps off the water pipe and supplying the condenser and the reflux pipes with independent water supplys.
Posted:
Thu Mar 01, 2012 7:24 am
by Admiral Toad
Mr Cat one would probably do if you then split the outlet 2 ways. it adjusts from 1 bar up to 6 or more as I recall so you still need needle type valve control to fine tune temps I would think cos even at lowest
pressure the volume would be far more than you would need
I found turning it well down gives loads of '
pressure variation play' on the mains side with a lower steady flow on the needle valve/ still side
Hope that makes sense
Posted:
Fri Mar 02, 2012 11:18 am
by MrCat
It makes sense but what I was thinking was that by splitting the water supply onto two separate regulated flows you would get no interaction at all between the condenser and the column.
I haven't split the water feed on the T500 but when I split the water supply on the ss reflux with a y connector and a tap in one of the feeds what happened was that when you increased the water supply to the column it obviously reduced the water supply to the condenser so you had to increase the water through the main tap and then reduce the water on the column etc etc
I ended up with a y connector to split the water, a tap in the column feed and a tap on the 'output' side of both the column and the condenser to ensure sufficient back pressure.
Mind you I ended up computer controlling the whole lot of it!
If I split the water supply on the T500 I'm going to use two independent water sources just to make it easier.
Posted:
Fri Mar 02, 2012 12:59 pm
by Admiral Toad
Ahh now I understand the 'cooling for cats'
Posted:
Fri Jun 29, 2012 9:40 am
by paul parker
Pressure reducing valves helps in controlling the water pressure and in a way conserve water.
Posted:
Fri Jun 29, 2012 12:10 pm
by Admiral Toad
Hi Paul and welcome
Its really being used to keep a constant
pressure and therefore flow to the condenser against fluctuations caused by other taps, loo flushing or even in the water supply
The T500 temp varies dramatically on the tiniest changes of water flow and this truly cures it 99%
Posted:
Sat Oct 21, 2017 3:45 pm
by Duffer26
Could you possibly send me a link to this valve?
Regards, Marc.
Posted:
Sat Oct 21, 2017 3:53 pm
by H12rpo
Slightly off topic, but does anyone have a ‘quick change’ system for changing coolant hoses between stills?
What I mean is a bit like the hozelock thingies only for smaller bore pipes
I have the T500 needle valve running off my outdoor brass tap into the T500 column feed and I’d like to be able to disconnect that tube after the needle valve and then connect a bigger bore tube onto that for my pot head
Not sure that has mad sense and I haven’t even had a drink yet !
Posted:
Sat Oct 21, 2017 7:18 pm
by packapoo
Try goog 'uxcell water fittings', see if those are any use.
They're similar to what you see on a host of plumbing jobs around stills. I forget the name for the real jobbies - it's a male person's christian and surname, may jog someone's memory...
Otherwise, I find the braided S/S water couplers most useful, particularly if you take the time to separate the end fittings. (Braid is then handy as bazooka on the mash tun.....)
Posted:
Sat Oct 21, 2017 9:10 pm
by packapoo
John Guest was the name (I finally recalled)
Posted:
Sun Oct 22, 2017 6:47 am
Yup John guest is a good call. Push fit.
I like these.
https://m.ebay.co.uk/itm/ZINC-CHROME-HO ... mwBanner=1They are are smaller than hoze lock, but would still need a 15mm hose tail.
