T500 and SS Super Reflux Similarity ?
Info specific to the T500
Postby Iain » Sun Mar 30, 2014 5:03 pm
Well long time no post .. house moves (got one not on a water meter again :) )
Looking at a T500 and was wondering if the barrel section is the same as the SS Reflux .. ie. would a t500 lid fit on the SS Reflux and vice versa?
Hopefully someone knows !
thanks all
Iain
Iain
Re: T500 and SS Super Reflux Similarity ?
Postby Icefever » Tue Apr 01, 2014 10:40 am
I've only just had my 500 but if it's any help I could measure the boiler tonight and let you know....from what I've seen on photos they do look the same.
Postby Iain » Tue Apr 01, 2014 5:40 pm
Fantastic .. would be great if you don't mind please :)
thank you !
Iain
Iain
Postby Icefever » Tue Apr 01, 2014 6:55 pm
Just had a look, the boiler is 1 ft across..(307mm) the seal in the lid is very wide...10mm so any boiler around that size I think it would be ok.
Postby Normski » Fri Apr 04, 2014 10:13 am
Just measured the Super Reflux.
Boiler is 298mm at Rim outer edge.
Inside of boiler is 285mm.
Norm
Normski
Stills: Super Reflux
Postby Iain » Fri Apr 04, 2014 12:34 pm
So good chance it may well fit .. that could be very very useful :)
thanks all !
Iain
Iain
Postby Anavrin » Fri Apr 04, 2014 3:14 pm
Can I ask what size the hole for the column is in the lid, I'm building my own column but may buy a T500 boiler
Postby Icefever » Fri Apr 04, 2014 6:32 pm
Hi...
It's a 1.5" BSP backnut..take a look at VT's build....Here
Also this Here
Postby Anavrin » Sat Apr 05, 2014 10:54 am
Any chance you can tell me the diameter of the hole in the t500 top?
I've got a 54mm compression fitting which is a tank connector the threaded part is similar to the diameter of the column so I was wondering if this would go through the hole
Postby YHB » Sat Apr 05, 2014 11:17 am
Sorry I cannot give you a dimension but the hole is sized to take a 1.1/2" BSPP threaded connector which is the same thread as the drain on the sink in your kitchen.
For anyone else reading this post and for the avoidance of doubt - I am talking about an English kitchen.
Postby Anavrin » Sat Apr 05, 2014 11:51 am
Think that's too small for my connector, domestic drains are 42mm, might go along the route of getting some of these 1 1/2 inch nuts, it would be easier to detatch the column with this type of connection anyway.
Postby Anavrin » Sat Apr 05, 2014 11:58 am
Might get one of these off ebay and solder the supplied nut into the bottom of my column
http://www.ebay.co.uk/itm/WASTE-FITTING ... 337f1da67a
Postby YHB » Sat Apr 05, 2014 4:25 pm
Looking good.
With that adaptor you could connect a 2" column to any lid.
It states that it for a stainless steel sink, it does not say it is a stainless connector, many are shiny plated steel, it may be worth asking the question, if it is ss then I think you are nearly there.
Postby Icefever » Sat Apr 05, 2014 5:32 pm
I think you'll find that they maybe chrome plated.... :-\
Return to T500
