First ever whisky...
Postby guest5234 » Sat Oct 22, 2016 8:35 am
I am going to try a whisky for thr first time using my grainfather with the Alembic Pot Still Condenser. Does this sound OK guys.
6kg maris otter crushed malt mashed and then fermented out.
25 litres into boiler for strip run, run quite quick throwing the first 100ml and saving the rest.
Spirit run throwing the first 100ml and collecting in several jars the heads hearts and tails.
keep the hearts for drinking and keeping the heads and nails for next wash?
Does that sound OK or and advice guys.
guest5234
Re: First ever whisky...
Postby Icefever » Sat Oct 22, 2016 8:42 am
Sounds just about right...there's a few of us on here that use either the BM or the GF.
Postby guest5234 » Sat Oct 22, 2016 9:18 am
cheers Sir, any tips?
guest5234
Postby Icefever » Sat Oct 22, 2016 9:25 am
You'll need oak..either dominoes or BBQ chips....what's your thoughts on storaged??
Postby Anavrin » Sat Oct 22, 2016 9:43 am
I think for Whisky, while stripping it pays to go a little deeper into the tails, I'm sure Easydrinker once mentioned he stripped down until the product from the still was just 10% ABV.
You might have to work through a full sack of grain to get enough strip for your spirit run, maybe consider adding some peat smoked grain too.
Also once you made your first spirit run, keep all the head and tails you not drinking as feints, this can be added to your next spirit run to add more flavour.
Roberts the Whisky man, I'm sure he will add anything I've missed.
Postby guest5234 » Sat Oct 22, 2016 9:44 am
going to look for an oak barrel, whats the oak chips like...I have a bag of jim beam BBQ smoker chips.
guest5234
Postby Anavrin » Sat Oct 22, 2016 9:45 am
Also worth noting is you don't need to boil your wort, although some people do for 10mins just to sterilise the wort
Postby guest5234 » Sat Oct 22, 2016 9:59 am
yep I am used to boiling after sparging will do it for a few mins.
guest5234
