Cheap Malt Extract
Cheap Malt Extract
Postby billmcc » Tue Oct 02, 2012 9:05 am
http://www.amazon.co.uk/Suma-Malt-Extra ... B005KRFNS2
This could possibly reduce the price of a whisky wash i understand that this is a food grade extract but i have read that home brewers are using it with success
what do you think
billmcc
Re: Cheap Malt Extract
Postby Admiral Toad » Tue Oct 02, 2012 11:33 am
Hi Bill
Me and the Cap'tn got 25kg of LME from the Worcester hop shop for £48 plus carriage but you need to contact them as this quantity is not on the website
Best price so far ;)
Admiral Toad
Stills: pothead, BP column
Postby billmcc » Tue Oct 02, 2012 12:16 pm
Thanks mate just trying a small amount first to see how it turns out have you a recipe please
billmcc
Postby Iain » Tue Oct 02, 2012 7:22 pm
I have looked at the suma stuff before but had some pretty negative responses from people on the homebrew sites about it !
I have however used the holland and barret stuff with good success if that's any help ?
Iain
Iain
Postby Admiral Toad » Tue Oct 02, 2012 8:39 pm
Bill
Basically making it up as I go along
Got 25kg of peated malt from the same mob, hand ground and mashed approx 5kg for a 25 l wash
Made up the OG with the LME to give about a 11% ABV
So far so good much flavour after a few weeks in the wee cask
The ones I've done and put in demi's with whisky barrel shavings rant much op think they may go in as feints in future runs. These didn't use peated malt however.
Admiral Toad
Postby billmcc » Tue Oct 09, 2012 9:58 am
Hi AT do you ferment on the grain or just use the liquid after cooking/mashing
billmcc
Postby Admiral Toad » Tue Oct 09, 2012 6:47 pm
Hi Bill
Last one I did I mashed and sparged 5kg of hand ground peated malt in a Muslim type bag some fine flour got through but basically clean wort lovely sweet and smokey
Added some LME to boost ABV and body
The spent grist or draff I think it's called was totally tasteless and without smell
Can only assume cattle are about as picky as lager and alcopop drinkers. ;D
Admiral Toad
Postby Almanac » Wed Oct 10, 2012 10:22 am
Admiral Toad wrote:
"Can only assume cattle are about as picky as lager and alcopop drinkers."
Meeooow! :D :D :D
Postby billmcc » Wed Oct 10, 2012 2:18 pm
Just put down my first wash using the Suma Liquid barley malt extract and used
4kg sugar disolved in 3 ltr boiling water with 1 spoon of citric acid
then added the 3.18kg liquid malt extract and mixed
then 0.5kg peated barley malt covered with 3 ltr boiling water and cooked in the slow cooker for one hour on warm setting, after 1 hour strained the liquid and added this to the wash then topped up to 26 ltr with cold water,using 1 ltr of wash i made a yeast starter using
2tsp of brewers yeast
0.5 tsp epson salts
1 tsp calsium carbonate
4 tsp dap
10 tsp distillers active dried yeast
hydrated for 30 min and pitched at 34 deg c
lid on air locked and bubbling like crazy in no time.start sg was 1.110 and predict final sg to be 1.010
i am expecting 13.5 abv from this brew so the yield should be good
billmcc
Postby billmcc » Fri Oct 12, 2012 1:57 pm
What about this £52 for 8 and free shipping
http://www.arjunawholefoods.co.uk/index ... xtract-7lb
billmcc
Postby RickyRasper » Mon Jan 14, 2013 5:06 am
Try Holland&Barrett a 454g Jar cost's £2.35 that works out at £11.75 3.5Kg for the same amount. The specs state that the malt contains 65-75g of carbohydrates per 100g. This is a really good carbo count and I may try it myself.
http://www.hollandandbarrett.com/pages/ ... rodid=3450
RickyRasper
Stills: Copper Alembic Pot
Postby Frank » Mon Jan 14, 2013 7:34 am
In Australia ::)
a 11 litre/15kg 'growler' of light or amber LME costs about $85 (ie. 55 pounds)....so aren't you guys lucky!!!
For example:
http://www.ibrew.com.au/collections/malt-extracts/products/briess-bulk-malt-growlers
I use it for Fine Scotch Whisky and, whilst $$$$, it has always been of good quality IMHO.
(see http://www.stillsmart.co.uk/forum/viewtopic.php?f=1&t=524#p9100 for recipe)
Frank
Stills: Potstill,LM Boka
