Possible secondary fermentation?
Postby Thunderbird » Tue Nov 08, 2016 10:25 am
Hi guys, I'm still in the process of making the Still Spirits 'triple distilled' turbo wash. At 7 days I checked the SG which was .992 and the reading was the the same on day 8. Thinking it might need a little more time I left it over the weekend and checked again - still read the same. So, although the SG is a little higher than the instructions recommend, I figured it had probably fermented out.
So, I degassed it and added the finings as per instructions. Now here's the problem. I checked it this morning to see if it was clearing and it was. Beautifully clear but with a tiny bit of froth on top. I thought this might have been due to staring in the finings but as I looked there were bubbles coming up from the sediment. Is this normal or uncommon?
Has the wash gone into secondary fermentation? If so, what do I do about it? Do I just leave it for a couple more days or should I rack it off the sediment and degas again? Any advice will be very gratefully accepted.
Thunderbird
Re: Possible secondary fermentation?
Postby Easydrinker » Tue Nov 08, 2016 10:54 pm
I would rack it off again and degas.
Leave a couple more days and rack into the still.
When you are new to this it can all seem scary.
As you put brews and distillations under your belt, then it becomes almost second nature.
Then maybe research alternative washes.
Maybe save your self some cash and some grief. ;)
Postby Mash » Wed Nov 09, 2016 7:35 am
Are you degassing by whipping or shaking?
If so I would guess you have roused the yeast, by getting some air in.
No panic.
Getting air into a stuck ferment is 80% of restarting process. That's what you have done.
Let it finish and then distill.
+1 what Robert said. Try some other recipes. Kale /lentil/tomato paste/www etc.
Threes things that are pointless IMO for spirit ferments
* degassing
* fining
* turbo's
Postby Thunderbird » Wed Nov 09, 2016 10:57 am
Thanks for that guys. Yes, I degassed by stirring it up vigorously. I only used the turbo stuff because it's what came with the 'starter kit'. In future I'll probably try different recipes though.
Thunderbird
Postby Easydrinker » Thu Nov 10, 2016 12:15 am
Mash wrote:Are you degassing by whipping or shaking?
No panic.
Three things that are pointless IMO for spirit ferments
* degassing
* fining
* turbo's
Postby Curmudgeon » Thu Nov 10, 2016 3:39 am
I am too smart to disagree with Robert in general, but will make an exception for degassing for small stills including an airstill
I've never had an explosion and am quite happy to keep it that way. Theory involves all sorts of have bits in the wash to avoid surge boils etc, pressure comes out the ethanol outlet etc, but bottom line is nothing holds the lid on.
I have distilled before a wash has completely finished so has had fizz still in it. Short version is with an airstill have it below a shelf so the lid can pop but go nowhere far and with "proper" still have lid well clamped on, loads of headroom and ideally a vent/valve/cork that can release but be contained without becoming a bullet or other missile.
Curmudgeon
Stills: pot head
Postby Easydrinker » Sat Nov 12, 2016 12:11 am
Hey, argue with that Robert geezer, it keeps him on his toes!
Your points regarding an air still are valid.
And your workarounds good. ;)
Postby Thunderbird » Sat Nov 12, 2016 10:29 pm
Thanks for the info chaps. :)
Thunderbird
Postby Mash » Sun Nov 13, 2016 7:12 am
Curmudgeon wrote: Short version is with an airstill have it below a shelf so the lid can pop but go nowhere far and with "proper" still have lid well clamped on, loads of headroom and ideally a vent/valve/cork that can release but be contained without becoming a bullet or other missile.
I do think missile is a bit strong - they burp and fart. Sometimes get a 2-3 foot spray going but I have never heard of the lid actually leaving. I don't think there is enough energy to do that.
Copper in the bottom (some of which should be flat) & a good seal, and everything should be okay.
SIMPLE TEST. If you can pick up the empty boiler by the lid . The seal is okay. If the boiler drops off the seal is due for replacement IMO.
Postby Icefever » Sun Nov 13, 2016 9:18 am
When I used mine I never had a problem. Good advice about the seal Mash..
Postby Curmudgeon » Tue Nov 15, 2016 2:33 am
Sounds like when my son was a babby and I never let him aim his escape valves at my face ;)
I suggested bungee cords here one time and was corrected, so I settled for running the airstill with top about 3 inches under a very sturdy shelf, but have never had a problem with the lid at all so far.
Curmudgeon
Stills: pot head
Postby Easydrinker » Wed Nov 16, 2016 12:02 am
I now cannot shake the image of an airstill lid parachuting back down to Earth, after being blown sky high. ;D
Postby Mash » Wed Nov 16, 2016 6:44 am
LOL.... nor can I now !!
Postby Curmudgeon » Wed Nov 16, 2016 7:28 am
I re-read the thread and see lots of bungee cord references but no parachutes.
You guys are wierd
Hotlips for the win
Curmudgeon
Stills: pot head
Postby RumJohn » Sun Dec 18, 2016 1:04 am
I have never seen an Airstill. Are they a pressurized system? I would doubt it.
RumJohn
Stills: Homegrown
