low ph
low ph
Postby paul » Thu Nov 13, 2014 5:28 pm
hi fellow distillers just a quicky what do i add too a low ph its 3.4? its a tp and bakers yeast wash thats taken 2weeks to get to 1050 so far?
paul
Re: low ph
Postby paul » Thu Nov 13, 2014 5:47 pm
anyone? iv added baking powder 1tb but it aint done nothing? :(
paul
Re: low ph
Postby Anavrin » Thu Nov 13, 2014 7:19 pm
Hi paul
You want Baking Soda (bicarbonate of soda), not Baking Powder, see the difference here
http://chemistry.about.com/cs/foodchemi ... baking.htm
I would mix 1 teaspoon with water to dissolve it, then pour it in and stand back!!! lots of impressive bubbles, but can overflow your fermenter so add it slowly.
then check your PH and add more if needed
Re: low ph
Postby Almanac » Thu Nov 13, 2014 8:12 pm
It sounds like the TP recipe may not suit your local water conditions. My water supply has very little limescale (Calcium Carbonate) and I can't get the TP recipe to ferment out because the pH takes a dive before the yeast can do it's job. This is because Tomatoes are naturally acidic plus manufacturers routinely add Citric Acid to Tomato Puree/Paste ::)
Check your local water supply or just look in your kitchen kettle. If there's no limescale in it and you don't have to use a regular de-scaler, the chances are the TP recipe won't suit your water.
You can always try the Lentil recipe it works brill in low limescale water ;)
AM Image
Re: low ph
Postby paul » Thu Nov 13, 2014 8:34 pm
thanks AM ill try the lentil wash this weekend if i find the recipe :-[ have i buggered it by putting baking powder in AM
paul
Re: low ph
Postby paul » Thu Nov 13, 2014 9:14 pm
anavrin wow you wasnt kidding about the bubbles ;D thanks for the bi carb trip lets hope it kicks it of again,i have found the red lentil wash recipe and will get that on the go at the week end thanks AM for that its your recipe ;)
paul
Re: low ph
Postby Almanac » Thu Nov 13, 2014 9:16 pm
paul wrote:...have i buggered it by putting baking powder in AM
Not necessarily. Baking Powder contains an amount of Sodium Bicarb but also contains acidifying agents which you don't want. That should make a difference ;)
AM Image
Re: low ph
Postby paul » Sun Nov 16, 2014 2:33 pm
aidanmac i started your lentil wash recipe friday evening and its going great guns thanks for putting it on ;D ;D my tp wash has nearly finished to its been 3 weeks tho and still not there but getting close
paul
