Who has made UJSSM
Who has made UJSSM
Hi Guys
I'm going to have a go at a multi generation UJSSM, there's an easy to follow guide here
http://homedistiller.org/forum/viewtopi ... 32&t=39682
It's not the original UJSSM thread as that is over 150 pages long
Just wondering if anyone else has done it, I'm assuming once into 4 or more generations you will get something similar to Corn Whisky, don't quite know what that tastes like but I'm assuming it's not a million miles away from Bourbon, anyone got any experiences they want to share?
Re: Who has made UJSSM
I know that there are people here that have tried this.
Today's silence means that they found it unremarkable, or they have not yet read your post.
I haven't tried it, so cannae say.
I have a hand written copy of Uncle Jessy's moonshine recipe somewhere, but not seen it in years. Malted corn, sugar, branch water and yeast was about all.
I make it pretty regularly.
- Stills: Air Still
@wormwood
If you make it often, what's it like as a drink, is there a commercial spirit you would compare it to?
I'm thinking to get a UJSSM going and along side it, also make a rye/malted barley wash or two, then combine the strips during a spirit run to see if I can create something like bourbon.
Methinks that you hope too much, but if don't set yourself a goal, then how do you smash it?
Best of luck here.
Best of luck here.
Anavrin wrote:If you make it often, what's it like as a drink, is there a commercial spirit you would compare it to?
I usually drink it white. I'm not very familiar with the current crop of commercial white whiskeys, but I think my cuts are much better than Georgia Moon and crap like that. Young and white, UJSSM has a nice sweet corn flavor, with a bit of typical sugar shine bite. Over time, it loses the bite, but also loses that fresh corn flavor. Give it some time on oak and it rounds out quite nicely, although I'm not sure it's ever going to compete with a real top shelf bourbon. That said, I've never left any on oak for five or ten years, so I don't know...
All of this strictly my opinion, based on my ingredients (cane sugar, feed store corn, bread yeast and filtered water, with eggshells to buffer the ph) and my methods (ferment aound 80 deg F, about 25 - 30% backset, double distilled, sometimes a 1.5 run) - I'm sure any of this could be tweaked, but I like the results I get.
It's fast, reliable and cheap - definitely worth trying. That said, if you're going to be doing an all grain with barley and rye anyway, you might as well malt some corn as well and make real bourbon.
- Stills: Air Still
I got into a right sticky mess last time I tried to malt corn, not easy to get hold of any decent enzymes over here in the UK, I tried gelatinising some corn and mixing in some malted barley and rye to get it to convert, but I got a very poor conversion, off a 25 litre wash I only collected about 2-2.5 litres of strip, can't remember now if I added any sugar, possibly not from memory.
I'm thinking if I could use UJSSM to get corn whiskey strip, then add rye/barely strip to the boiler charge I could possibly make a bourbon spirit, still the same ingredients just added together at a different stage.
Two chances I guess
Two chances I guess
I was wondering what the availability of malted corn might be like in your neck of the woods?
Same as it is in mine. Apparently.
Malted Corn, now that would be something to behold, I'll have to add it to my list for Farther Christmas
The trick to malting corn is to use white corn or red corn, rather than yellow corn. Back when I grew my own, I sprouted it in mason jars with lids like these:
https://www.amazon.com/Sprouting-Jar-St ... B000WRZODY
Not growing my own corn right now, so UJSSM with feedstore yellow corn is my main whiskey and it is less hassle, even though the results are less smooth. No experience with enzymes (other than the naturally occurring ones) so I can't really comment on that.
- Stills: Air Still
I started mine today, had to convert the US recipe to metric so this is what I've come up with.
I used a 60 litre fermenter for a 40 litre wash, although once the corn and sugar is added, it sits on the 50 litre mark on the bucket.
My recipe is
8kg of cracked corn
8kg of sugar
40 litres of water
Full tin Allinsons bread yeast
Method
Add the corn and sugar to the bucket while heating 20litres of water to 35°c.
Mix the warm water in the bucket to dissolve the sugar.
Heat another 20 litres to 25°c and top up, mixing lots to disolve the sugar.
The final temp was 28°c, added a full tin of Allinsons, let it sit on top for 15 mins before mixing in.
Of course this is just the start, next time I will have backset to add, I'll keep
A record of my progress here, starting SG is 1.070
My recipe is
8kg of cracked corn
8kg of sugar
40 litres of water
Method
I think this is nearly done, I'll strip it over the weekend and start the second generation using 10 litres of backset, also when I strip the next lot, I will add this first strip to the boiler as the first strip is "sweet" (no backset used) after this each generation will be sour.
Job done, stripped it and used 10 litres backset to disolve another 8kg of sugar and refilled the bucket for the next generation, I altered my plan slightly, after I removed the top layer of spent corn, I decided not to replace it with new corn as the amount already in there was up to the 15 litre mark, next time I will add new corn to replace what gets removed.
Got 7.5 litres of strip down to 20%, it also fermented below SG1.000 without any added nutrients, it was just cracked corn, sugar, water and bread yeast.
Not checked it this morning yet, hopefully I didn't kill the yeast off and it's fermenting once again.
EDIT : just popped in the guarage and its bubbling away nicely, at this rate I recon I will get through one a week.
Users browsing this forum: Easydrinker, Google [Bot] and 1 guest
