De-ginification
De-ginification
Postby Mash » Fri Jan 01, 2016 7:55 am
Due to the recent arrival of sputnik I have been making more experimental gins.
Having learnt from them I would like to remove the flavours and return them to a neutral for another go.
Will a carbon filter do this, or is it asking a bit much?
I guess a column would too?
Re: De-ginification
Postby chill » Fri Jan 01, 2016 7:15 pm
I have carbon filtered some of my failed experiments. My experience is that it won't return them to a true neutral, but it will get most of the way there. I save the result for new experiments but keep in mind that the flavour might be slightly skewed. I am not sure that a column would do any better as even at 96.5% you are still getting 3.5% of something else and some of those botanicals have staying power.
Re: De-ginification
Postby RumJohn » Sat Jan 02, 2016 1:17 am
@ Mash: Redistill, a couple of times if necessary, but with lots of water in the boiler. A good amount of your problem will be left in the boiler.
Make sure your equipment is clean. Your run can and will pick up unwanted flavor. Your still is not a teapot.
RumJohn
Stills: Homegrown
Re: De-ginification
Postby Mash » Sat Jan 02, 2016 6:51 am
I did wonder if diluting it to 20% and letting it s stand for a week before re distilling might help?
Re: De-ginification
Postby Phantom » Sat Jan 02, 2016 12:23 pm
I'm thinking a couple of reflux runs, letting it down with RO or distilled water to the 20 or 30% area, with a good clean out of the still and column in between runs, then a final visit to a nice clean batch of carbon should do the trick.........
Re: De-ginification
Postby Mash » Sat Jan 02, 2016 3:16 pm
Sounds like I need a big boys column then. Thanks chaps.
