AV Corrections Table for High Temps
Postby packapoo » Thu Oct 22, 2015 11:49 pm
Can anyone point me to such a table please?
I know I've seen one somewhere, can't find it.....
Have been pointed to one published by Husker, it doesn't like my input ???
Re: AV Corrections Table for High Temps
Postby Easydrinker » Thu Oct 22, 2015 11:59 pm
Wash or Spirit hydrometer?
Could probably post something on the morrow, if not beaten to it.
Postby packapoo » Fri Oct 23, 2015 12:17 am
Spirit hydrometer Robert, thanks.
Postby Easydrinker » Fri Oct 23, 2015 12:52 am
Does this tick the boxes?
Postby packapoo » Fri Oct 23, 2015 1:31 am
Ahhhh, no it doesn't. Haven't seen that before Robert but can probably work it.
Question though....I'm reading AV% at the still take off at temps typically around 80C and above.
Does this work there?
That table stops adjustments at 35C - would the adjustment be greater for higher temps or am I going about this the wrong way?
Postby packapoo » Fri Oct 23, 2015 1:37 am
Ahhh, now I savvy!
Thought about where I'm going wrong. Temps I'm reading are at the still head before any cooling. Distillate won't be dropping into my jar at any temp as high as I'm looking at there. It's warmish but not that warm.....
Ahhh, now I savvy!
Postby Easydrinker » Sat Oct 24, 2015 12:54 am
"It's life Jim, but not as we know it"!
Postby packapoo » Sat Oct 24, 2015 2:28 am
Life does get complicated though Robert....
I changed my way of doing things and took temps today @ distillate takeoff, along with alcometer reading then applied the table corrections.
Left things to cool for a couple of hours, came back checked temps 20C. Sweet.
So, got busy with the alcometer again. Not so sweet, variations from the table corrections across the board, up to 4%.
Revisited Huskers correction table and now able to align it with my alcometer.
At the end of the day I learned something.....once I corrected my fuzzy logic..... :-[
Postby Icefever » Sat Oct 24, 2015 7:00 am
Do you mean something like this Pack ??
I use this for all my temp corrections..
Postby RumJohn » Sat Oct 24, 2015 10:15 am
@Pack: For accuracy, I cool everything down to 20 C before measuring. I bought a frig just for my work.
However you should be able to print one off the internet.
RumJohn
Stills: Homegrown
Postby RumJohn » Sat Oct 24, 2015 10:18 am
@ Pack: You should have a product cooler on your PDA.
One reason I have never bothered with a parrot is the temp at that point.
RumJohn
Stills: Homegrown
Postby Mash » Sat Oct 24, 2015 5:28 pm
Better still use a refractometer
Postby packapoo » Sat Oct 24, 2015 6:31 pm
@Icefever
@RJ
@Mashy
Thank you gentlemen. In order now :D
Yes Iceman, exactly like that. Interactive is good....
There is a product cooler (liebig) on the unit RJ and like you I don't and won't bother with parrot for the same reason. Usually leave distillate to air and cool overnight, just trying to speed things up a little.
I have one of those Mashy. Used it for winemaking, never thought about it fr this :-\
Postby packapoo » Sat Oct 24, 2015 8:10 pm
Well that's not viable. Unless there is a conversion table for Brix/AV....
