Essencia and SS boiler lids: Same Size?
Postby Keystone » Sat May 28, 2011 3:23 am
Do the boilers for the Essencia and the SS Super Reflux use the same size lid? If so, what is the diameter of the hole in the Essencia lid?
Keystone
Re: Essencia and SS boiler lids: Same Size?
Postby Petem8 » Sat Jul 23, 2011 11:34 pm
Yes, however the diameter of the hole is larger on the essencia lid as the column on the express condenser is larger than the super reflux. Also you will notice the dome in the lid is taller than the super reflux lid as the express boiler is much more powerful and will produce more foam while boiling, the higher dome is designed to reduce the effects associated with foaming.
Petem8
