Benoits Basic Bouncing Parrot
Postby Benoit » Wed Jun 15, 2016 7:52 pm
Finally getting round to finishing a multitude of half done projects, apologies for my absence of late but Mrs Benoit has decided she no longer wants the title so the internet has had to take a back seat.
Anyway, here is my basic parrot: a 54x15 reducer, a 54x22 reducer, a 22x15x15 tee, some 15mm pipe, some 22mm pipe, a teeny bit of 8mm and a 15mm end cap
Slapped together with some fairly sloppy soldering and voilà!
But Benoit, I hear you cry.....Why bouncing??
Well the answer is twofold, one because I dropped it hence the slightly odd angle at the tee and two because I added this:
I wound it round a 10mm drill bit then gave it a little tap with a hammer so it held its shape. After that I poked it into the end of the tee before securing with (lots of) solder & scrap wire to fill the dead leg of the tee up. The spring sits to about an inch above the height of the tee & cushions the hydrometer when you drop it down, cost about £15 guesstimating the cost of the pipe in there
Re: Benoits Basic Bouncing Parrot
Postby Easydrinker » Wed Jun 15, 2016 10:15 pm
Loving the bouncing parrot.
Sorry about Mrs Benoits choice.
Postby packapoo » Wed Jun 15, 2016 10:26 pm
Echoing Robert's comments.
Postby Mash » Thu Jun 16, 2016 6:06 am
Nice build and a brilliant idea.
Postby Easydrinker » Thu Jun 16, 2016 11:47 pm
'Tis hard to tell whether that was a "AND MOVING ON, SORT OF POST" or "I didn't bother to digest your post and so obviously don't really give a shit" sort of post.
Pretty tasteless and thoughtless IMHO.
But that is just MHO.
Postby Mash » Fri Jun 17, 2016 7:23 am
I will elaborate. Its a nice build and all though there is reference to sloppy soldering, I have done much worse. The bounce is a very good idea - I cringe every time I insert a hydrometer in a parrot, and this is a very neat solution.
Can I have a star now please teach :)
Postby hampk » Fri Jun 17, 2016 12:26 pm
Been there, Benoit - commiserations. Nice parrot, though!
I seem to have got lucky this time around - we are celebrating a blissful 5 years of marriage today.
hampk
Stills: Airstill
Postby Anavrin » Fri Jun 17, 2016 9:26 pm
I once paid about £15 for a posh alcometer from love brewing, it's scale was from 70%-100%
About the second time I used it, it smashed while dropping it in my parrot :(
Great idea :)
I use the SD parrot with the bottom drain, it would be perfect if the alcometer didn't block the flow when draining, one of these would certainly kill two birds with one stone, protect the alcometer and stop it blocking the drain port.
Postby inspector gadget » Wed Sep 14, 2016 6:58 am
Off to my local plumbing supplies shop today for the necessary components, will get two lots just in case :)
inspector gadget
Stills: SmartStill,T500
Postby Benoit » Wed Sep 14, 2016 3:35 pm
I'm sure it wouldn't take long to sell the spare if you chose to!
Postby inspector gadget » Thu Sep 15, 2016 6:35 pm
Couldn't get the 54mm reducers so have had to compromise a bit, nearly ready just the outlet pipe and its hole to finish, set them at the correct height and solder me up Scotty...
inspector gadget
Postby Easydrinker » Thu Sep 15, 2016 9:23 pm
Mash wrote:I will elaborate. Its a nice build and all though there is reference to sloppy soldering, I have done much worse. The bounce is a very good idea - I cringe every time I insert a hydrometer in a parrot, and this is a very neat solution.
Nope, 'cos this has been bumped, again, and you still don't realise what you did.
I can be a harsh b'stard, I know..
Postby Icefever » Sat Sep 17, 2016 6:30 am
inspector gadget wrote:Couldn't get the 54mm reducers so have had to compromise a bit, nearly ready just the outlet pipe and its hole to finish, set them at the correct height and solder me up Scotty...
Nice job there Gadget Image it's great when you "diy" bits of kit yourself.
I've done most of my own...and I'm in the middle of two projects at the same time...all I have to do is find the SMEGGING time to finish them...Image
Postby Easydrinker » Sat Sep 17, 2016 10:18 pm
Working days are getting noticeably shorter.
Brewing and distilling evenings are getting longer.
I knew that there was a logic to doing more over the winter...
