I usually end up at > 30%. Aidan has said that you get better separation of the distillate at 30% than running it at a higher ABV. That said, I have run it at up to (I think) 45%. It is not the end of the world. You DO need to make adjustments to how much you collect as you have more alcohol in the 4L, you will have more coming out. The easiest is to just collect more small jars at the start and end. I collect in small jars after the standard 250ml heads and before I start collecting hearts. I sample these after airing and some go in the heads and some I keep as hearts.
