Ceramic Boil Enhancers
Postby popcorn sutton » Fri Feb 27, 2015 12:05 pm
hi guys
another question Ceramic Boil Enhancers.silly question but how often do you replace them
thanks
popcorn
A glass of whisky in Scotland in the thirties cost less than a cup of tea.
popcorn sutton
Stills: airstill
Re: Ceramic Boil Enhancers
Postby Mash » Fri Feb 27, 2015 1:29 pm
I replaced mine with 1p's - never looked back.
About 50p worth... or about 1/2 tumbler depending on how you measure 'em ?
Postby Easydrinker » Fri Feb 27, 2015 1:35 pm
The straight answer is when they fall apart,which they eventually do.
By the time my first half packet had started to disintegrate,maybe after 30 uses,I moved on to copper pipe offcuts instead of ceramic and never used them again.
Postby RumJohn » Wed Mar 11, 2015 12:39 am
I throw a good quality SS pot scrubber into the boiler.
RumJohn
Stills: Homegrown
Postby popcorn sutton » Wed Mar 11, 2015 9:40 am
Easydrinker wrote:The straight answer is when they fall apart,which they eventually do.
whats the benefit of copper pipe and how much do i use
mick
popcorn sutton
Stills: airstill
Postby Mash » Wed Mar 11, 2015 10:03 am
Copper is said to purify the spirit. I think it might be tried into neutralizing sulphites.
Even is SS columns you find many folks add a few bits of copper.
So copper is a good thing.
With an Airstill you are trying to stop puking. Which is caused the water super heating. Movement, even the smallest vibration will stop superheating and promote a gentle simmer thus mitigating the risk of a puke (or surge)
So IMO you need to cover the bottom of the still. As the bubbles generated by boiling move the rings and create ripples.
Very similar to the big glass lump you can buy to stop milk pans boiling over .. think they were called milk savers !
Postby Icefever » Wed Mar 11, 2015 10:13 am
mick
It removes sulfur-based compounds...Image which don't taste nice....how much??? in an airstill half a mug, maybe a little more, there's no set measurement...
just cut up a piece of copper into small bits, it's all down to surface area..
Postby Sunshine » Wed Mar 11, 2015 10:42 am
Hi!
To the question copper or no copper we had some interesting discussions:
https://www.stilldragon.org/discussion/ ... ment_23365
https://www.stilldragon.org/discussion/ ... ion#latest
Sunshine
Stills: All StillDragon®
Postby Icefever » Wed Mar 11, 2015 6:38 pm
I think the jury is still out on this one Sunshine.
Postby Sunshine » Wed Mar 11, 2015 7:34 pm
well, at distilling class they said, that certain washes don't need copper at all.
Also as I am from the business, I had a talk with the main sales person from Carl, he said that the real reason, they want to sell more copper than SS is, it is cheaper for them to produce.
It is a question, that will stay for much longer, I guess.
Sunshine
Postby Easydrinker » Thu Mar 12, 2015 4:15 am
While I remain convinced that the use of a lot of copper in a still or condenser is good,I will leave others to form their own opinion.
If anyone here,that strives for a malt whisky has not read "Peat Smoke and Spirit" can I suggest that they do?
It does suggest that the choice or style of condenser is not left to an individual distillery manager,but is now corporately dedided.
Postby Sunshine » Thu Mar 12, 2015 7:48 am
I don't suggest anything, I use copper in my still myself.
I just say: the copper discussion is a never ending one. And it is well worth reading ;)
Things will always change: the more distillers there are, the more experience is made and the more different approaches will be. It is an exiting hobby and a very interesting profession.
Sunshine
Postby popcorn sutton » Thu Mar 12, 2015 9:12 am
Sunshine wrote:I don't suggest anything, I use copper in my still myself.
;D
popcorn sutton
Stills: airstill
Return to Distillation
