New to Alcohol Distillation
Postby steven7 » Tue Oct 08, 2013 8:22 pm
Got a Still Starter Kits because it look simple and easy to do was I wrong :(
Added 4L of wash for 2 hours for 700ml and the alcohol strength was 56% dilute by 350ml water . Next was run through the carbon filter for 6 hours and added my Still Spirits Pure Vodka Flavouring .
Only thing it tastes like paint stripper I only saw this website and found that the air still is rubbish and the Air Still Instructions are wrong.
the homebrew site is saying I have a actual replicated drinking situation
I did ask would a spirit run help he said "No it wont. Much better running it through carbon again.
Seriously we might need to look at better carbon treatment like the Z Filter "
But thanks to this site I have some good reading to be done with good Instructions sure I will get there in the end
steven7
Re: New to Alcohol Distillation
Postby Easydrinker » Tue Oct 08, 2013 9:04 pm
Hi and sorry you found out the hard way.
The Air still is a fine and useful piece of kit,just not used the way that retailers suggest.
There is lots of reading in the Smart still/Airstill section,and the brief by aidanmac,and mozr's articles will have you producing quality drinking spirit in no time.
Hang in there,it is worth it.
Postby chill » Wed Oct 09, 2013 1:36 am
As EasyDrinker said, the AirStill is not rubbish. It just needs to be used correctly with good quality washes. I am enjoying a Bourbon made in mine as I type this. Personally, I don't really fancy any of the flavourings but you may have better alternatives where you are.
Postby John51 » Wed Oct 09, 2013 2:49 pm
If you go the strip/spirit run route, I can recommend using a cheapo 300w light dimmer on the spirit run to improve quality. I had the power down to 160w so it takes a while but no never mind as it doesn't require your full attention all the time.
http://www.ebay.co.uk/itm/Dimmer-Socket ... 35c9902835
Not quite as good as what I get from my T-500 but acceptable to me and most of my friends when drank unfiltered but with a mixer. I gave a bottle to friends that had been flavoured with 'Bombay Gin' and they loved it.
The manufacturers are imo less than honourable in their pushing of consumables. Do everything their way and you get a lesser quality product that costs almost double than the best way of doing it.
John51
Postby steven7 » Wed Oct 09, 2013 4:12 pm
Thanks had a look over the aidanmac pdf will need to get more glassware for the for the spirit run .
Sent away for the dimmer, would a 3 Pin Kettle Female Plug 13A(old PSU) work for the fan ?
steven7
Postby Easydrinker » Wed Oct 09, 2013 6:25 pm
A kettle lead should be fine for the fan,If you want it to run at full power.I chopped an old lead for the dimmer (female connection to still male), when I played with lower power,and let the fan run at lower power too.I could have used the stills original power lead to the fan for full fan power.
You might want to put a lower rated fuse in though,13 amps is a bit high for a 320 watt appliance,the fan on mine is only about 20 watts,I found some 3amp,and felt happier.
Postby Almanac » Wed Oct 09, 2013 6:46 pm
steven7 wrote:Thanks had a look over the aidanmac pdf will need to get more glassware for the for the spirit run .
In your neck of the woods you won't have any problem getting 1lt Kilner Preserve Jars which I found perfect. You could also get mates to hold onto jam jars for you too. Either will do the job.
Don't let your first experience put you off, you'll get there quite quickly and all the help you need is right here when you need it.
If you haven't chucked the first batch out you can simply recycle it by diluting it to 20% and run it again as a stripping run and keep the distillate until you do a new wash then add the stuff you save to the stripping run to boost the yield ;)
Postby John51 » Thu Oct 10, 2013 12:04 pm
Here's little mod I did to my airstill to make me feel better.
viewtopic.php?f=13&t=1408
John51
Postby steven7 » Thu Oct 10, 2013 3:38 pm
Thanks aidanmac was about to bin the old batch , see when I make the 1350 Ml on the stripping run do I just discard what's left in the airstill about 2.5L 18 % alcohol?
Done a search for the Preserve Jars looks like am cheaper off with jam jars and bin the jam :)
Thanks john for the mod link it's on my to do list
steven7
Postby chill » Thu Oct 10, 2013 4:17 pm
What you collect is higher than 18% (otherwise, what point would there be in distilling?). After you have collected 1300+ml, what is left in the still is probably less than 3% alcohol. You reach a point where it is not economical to continue collecting. If you just let the still run you would get out of it exactly what you put into it. Pointless.
Postby steven7 » Thu Oct 10, 2013 4:45 pm
thanks , makes sense now
steven7
Postby Almanac » Thu Oct 10, 2013 6:17 pm
I assume you have an Alcometer and a Trial Jar. These are essential with the Airstill as you must be able to tell when the output gets down to 20%.
If you were running a large conventional still you could collect right down to 5% like some of the commercial distilleries but at our level you really don't want to go that far and particularly with the Airstill it's just not worth it ;)
Postby Easydrinker » Thu Oct 10, 2013 6:55 pm
Not wanting to take your thread off topic,but why bin the jam?
A jar of Tesco Everyday Value Mixed Fruit Jam costs 29p and contains 277g of sugar.
20 jars in a 25 litre wash might produce a wash of 11-12%.
Perhaps not really an experiment for a new distiller,I'm not sure what effect the Acidity Regulator (Sodium Citrate),would have on the wash.
Maybe someone will come back and tell me this is a ridiculous idea,I hate to think of that jam going to waste!
Brainwave or brain fart,I can't decide.
Postby chill » Thu Oct 10, 2013 7:11 pm
Sounds like brandy to me! I had 12L of mixed fruit macerated in rum that no one liked (people don't seem to like 62% ABV desserts for some reason). I diluted, re-fermented, and distilled. Yummy!
Postby rhinus » Fri Oct 11, 2013 1:57 am
Welcome Steven,
All the guys are right on here. The airstill can be a lovely little machine. Aidanmac and Mozr's guides can get you making very nice spirits right away. Being a newcomer myself, here is what I use/do:
- bought a hydrometer and alcometer with testing vials. Bought lots of canning jars in various sizes. Bought stainless steel funnel with mesh screen.
-made John51's recommended modification to the plastic spout
- made only Tried and True wash recipes using baker's yeast, champagne yeast, and ec-1118
- add copper parts and ceramic bits to the boiler on each stripping run
- always use distiller's conditioner/butter on each stripping run
- on stripping runs I collect in a single 2lt canning jar. Once I get above 1lt, I collect in a 100ml small glass container so I can measure the ABV of each 100ml so I know when to stop. Then I pour it into the 2lt container.
- On stripping runs, I collect forshots in a shot glass and discard, heads straight into the 2lt heads jar, and everything after in 100ml small canning jars.
I following the methods found in the guides here have allowed me to make some very nice product. I'm still working on it and refining my techniques and recipes, but it is a smoothe enjoyable drink already!
Good Luck!
rhinus
“Always do sober what you said you’d do drunk. That will teach you to keep your mouth shut.”
~ Ernest Hemingway
rhinus
Stills: airstill
Return to Distillation
