First proper run .. Questions
Re: First proper run .. Questions
Postby Almanac » Fri Nov 14, 2014 7:31 pm
I just completed a Heads only run, after dilution I had 45lt @ 25%ABV (very low ABV for better separation in this case)
My Heads runs are made up of collected Heads from multiple Spirit runs from my Pot Still, with the Fores having been dumped on the original runs - that's just my way of doing it ;)
The first thing to remember about a Heads Only run is that there's going to be quite a lot of Heads produced and smearing is unavoidable. I simply dump the first 5lt - no questions - no smelling - no tasting ;D
The next litre or so is collected in 200ml batches and each is tested on the fly. When I reach the one with hardly detectable traces of the Heads I switch to 750ml collections until it gets down to 50%ABV
Remember, there are NO Tails in a Heads Only run. As the ABV drops the output gets too slow to bother with as the boiler churns out more and more water with the ever decreasing volume of Ethanol.
At the end of the run I had collected 8lt of clean spirit with a batch ABV of 69%. I'd call that a result and a 'Heads-up' about doing Heads Runs ;D
AM Image
Postby John51 » Sat Nov 15, 2014 11:29 am
Basic 24/25L wash with Vodka Star and 6Kg of white sugar.
I used to put the heads back in when using an airstill. At some point with recycling, the game stops being worth the candle. That varies person to person. Some get a kick out of being super efficient. I enjoy doing as little as possible for ok results. A matter of perception I suppose.
John51
Postby Capt-Cudellez » Sat Nov 15, 2014 3:22 pm
aidanmac wrote:The first thing to remember about a Heads Only run is that there's going to be quite a lot of Heads produced and smearing is unavoidable. I simply dump the first 5lt - no questions - no smelling - no tasting ;D
Should that not be 0.5L? ;D
Postby chill » Sat Nov 15, 2014 5:16 pm
This "dilution for better separation" thing has never made sense to me. Dilution for fire safety, that I understand. The boiling point of the still charge is based on the boiling point relative volumes of what is in the still charge. So adding water will increase the boiling point so I would expect it to be harder to separate out the elements with a lower boiling point (e.g heads). Not diluting it would result in a lower boiling point (it is mostly ethanol with ethyl acetate and some other bits). That should allow the ethyl acetate to largely boil off before much ethanol starts to come across. Am I misunderstanding something here? My last few heads runs have been of undiluted heads and I am (if my memory and calculations are correct) getting a lot more usable ethanol than when I diluted then back to 30-40% with baking soda and boiling water.
You do need to be cautious as with no water and no tails, you can run the still dry if you try to collect too much!
Postby Almanac » Sun Nov 16, 2014 10:36 am
:D :D I knew someone would go Whaaaaaat???? when I posted that :D :D but it's true!
On a normal 40lt @ 30%ABV spirit run I chuck the first 500ml down the sink as Fores. The next 2.5lt is routinely run to my Heads storage Cornie Keg. After that I start my Spirit Run in earnest by smelling and tasting distillate on the fly to determine the Heads/Hearts cut ;)
Note: The Heads I'm referring to here are from a Pot still and not from a Reflux column.
On a pure Heads Run there's no Fores but I expect a LOT of Heads to be present and smeared across the early part of the run. Hence, I discard the first 5Lt (five Litres) and only test the output after that point.
On the Heads Run just completed, the next litre, collected in 5X200ml lots, proved to be mostly contaminated with detectable Heads characteristics (something I describe as a sweet Pear taste) The fourth lot of the 200ml lots was mostly clear when tested on the fly and the last 200ml lot was included in the Hearts collection. (The 4X200ml lots rejected in this case are gone back into the heads storage and will be run again sometime next year)
In total, 5.8Lt of the output from that Heads Run was discarded as unusable and the remainder made beautiful Vodka some of which will be used to make some delectable liqueurs for Christmas presents, etc, and the rest is for SWMBO ;)
Mad, isn't it!! ::) But, many here have been at this a long time now and while I know I could squeeze another couple of litres out of my Heads by treating them for a few weeks with Sodium Bicarb and all that palaver I prefer the simple life these days. As in , 'take the good, chuck the bad and move on to the next' or Bish Bash Bosh! as I think they say these days.
Truth be told I'm probably just getting lazy in my old age ::)
AM Image
Postby Anavrin » Sun Nov 16, 2014 11:01 am
Hi aidanmac
I didn't question the 5 litres heads from a huge heads run as I thought it sounded about right but is it really worth keeping for next time after already being recycled once already?
I thought it was good practice to throw the heads collected from a heads run, saying that, I don't do heads runs.
On a big spirit run I throw the first litre after the fores are collected, then anything that doesn't make the cut goes into a feints jar to be added to the next big spirit run.
Saying that, I'm running a reflux column not a pot so I guess you will always have some ethanol content in there.
Postby Almanac » Sun Nov 16, 2014 11:02 am
chill wrote:This "dilution for better separation" thing has never made sense to me. .....
Truth be told I picked that up many years ago when researching this wonderful craft.
In the early days I read everything, visited every site and forum and absorbed as much advice and wisdom as I could along the way. In doing so I encountered many distillers with long experience. Some were following handed down practices and others were more technical and scientific in their approach to the craft. One of the many things I picked up along the was was advice that at lower concentrations, the volatiles, including the desireable ethanol, is easier to separate from the main body of liquid and I accepted that advice at face value because of the many sources it came from.
From a proof or qualification point of view I can only refer to my early days using an Airstill (which I use to this day for experiments). When I discovered the need to Double Distil with the Airstill I just put the Low Wines into the still and ran them. The results were not very good, even after carbon filtering.
I put questions to many of the experienced distillers I had encountered in my research as to why this was happening and the consensus was that I was getting smearing across the entire distillate and the solution was to dilute the low wines and reduce the power.
At that time I didn't have the technical know-how to reduce the power but diluting the low wines to 30% ABV did the trick.
Bottom line, I don't have a scientific explanation to offer just the benefit of my experience ;)
AM Image
I accepted this as fact based on experience
Postby Almanac » Sun Nov 16, 2014 11:11 am
Anavrin wrote:Hi aidanmac
I didn't question the 5 litres heads from a huge heads run as I thought it sounded about right but is it really worth keeping for next time after already being recycled once already?......
I'm with you on that. The first 5Lt went down the sink, never to be seen again :D The bit I kept was the 4X200ml lots from the 6th litre just before the Heart Cut. They weren't good enough to make the cut into drinking spirits but they were relatively clean and worth keeping to add to a future stripping run ;)
AM Image
Postby John51 » Sun Nov 16, 2014 2:48 pm
My take on the dilution for re-runs is that a weaker ABV will give less output for a given wattage. Therefore it takes longer to get that specific alcohol out. As there is less of it, less heat is given up to the column when the distillate condenses in the column, making the reflux rate higher and the output purer.
Pot stills have some amount of reflux factor so the same applies but maybe not as much.
As with most aspects of this hobby, the slower you do it, the better the results. Except sampling of course. ::)
John51
Postby Easydrinker » Sun Nov 16, 2014 11:47 pm
Boozoid wrote:
With regards to the heads and tails what should I keep? Do you recycle forever or do you throw some away?
Cheers,
This thread has sort of grown,but I hope Boozoid still thinks that we are answering his question.
Myself,handling the sort of run AM mentioned,would probably have similar percentages of the cuts.
I never seem to have enough BBQ,fire or bonfire lighting fluid,so look forward to the heads of heads to replenish stocks.
One of these days I'm going to try it in the mower-(having drained out the petrol).
Where I differ,is in my grain Whisky attempts,where I keep a feints container used and refilled from distillation to distillation,to add to stripped wash,trying for flavour carry through more than anything.This goes on and on,in an effort to emulate Scotch single malt distilling.
Recently I have started my own cut and paste library of pertinent and clever stuff that I find,to save time trawling back through pages of forum stuff.
Here is a gem of succinctness,posted by Myles,on another forum,I don't think he will object to my importing it here.
"Traditional pot stills will run a low wines charge of 28% for product at 70% - mostly to ensure consistent cut volumes at a consistent power input between runs. They also use the 28% charge to hydro-separate the boiler charge to aid cuts."
Users browsing this forum: Google Adsense [Bot] and 1 guest
