100ml jars ?
100ml jars ?
best place to get some 100ml jars for the sprit runs ? and should about 10 suffice ?
Re: 100ml jars ?
The cheapest jarred product that you can find in your local supermarket?
I use 540ml vinegar bottles, about 25p each from Lidl, previously emptied into a new build still for cleaning purposes.
You can use bigger collecting vessels when in the middle of the run, but this is maybe something that you need to experience first?
Apologies for being as clear as muddy water.
Re: 100ml jars ?
Thanks Robert i think i know what you mean ish.....
Re: 100ml jars ?
Easydrinker wrote:The cheapest jarred product that you can find in your local supermarket?
Might sound a daft question but these jars have plastic lids ,do you use them as well for storing until your next run ?
Re: 100ml jars ?
ninja_geezer wrote:best place to get some 100ml jars for the sprit runs ? and should about 10 suffice ?
The local boozer will have tonic bottles. The dumpy one's are great.
These are 150ml. They take a crown cork and a wine making plastic topped bung (port stopper).
The labels soak off in water.
Brilliant.
They only recycle [not return] so they are happy to give them away.
Cost - 1 pint of beer ... oh dear how sad
Re: 100ml jars ?
Get a pyrex measuring jug then take your 100ml cuts and transfer into jars of all shapes and sizes (pasta sauces, jam, honey etc)
When the wife is shopping tag along and get creative.
Brewhunter - Senior Distiller
- Stills: T500 + Airstill
Re: 100ml jars ?
When I started with my AirStill, I bought a dozen 190ml jam pots, and 'calibrated' each to 100ml with a dymo label (each one numbered so I don't get them muddled up!). Now I know my wash numbers, I don't use them except for heads runs, which are always variable, except the one marked at 50ml which I use for foreshots. I also possess two 400ml and two 2l laboratory-grade borosilicate glass beakers with which I can do pretty much everyting from making washes in the first place to processing strip and spirit runs.
Don't know if that helps or not, but it works for me.
Hampk
Hampk
hampk - Senior Distiller
- Stills: Airstill
Re: 100ml jars ?
Brewhunter wrote:Get a pyrex measuring jug then take your 100ml cuts and transfer into jars of all shapes and sizes (pasta sauces, jam, honey etc)
hehehe i like it
Re: 100ml jars ?
Mash wrote:ninja_geezer wrote:best place to get some 100ml jars for the sprit runs ? and should about 10 suffice ?
Brilliant.
Great idea
Re: 100ml jars ?
hampk wrote:When I started with my AirStill, I bought a dozen 190ml jam pots, and 'calibrated' each to 100ml with a dymo label (each one numbered so I don't get them muddled up!). Now I know my wash numbers, I don't use them except for heads runs, which are always variable, except the one marked at 50ml which I use for foreshots. I also possess two 400ml and two 2l laboratory-grade borosilicate glass beakers with which I can do pretty much everyting from making washes in the first place to processing strip and spirit runs.
Hampk
another great idea...
Re: 100ml jars ?
This forum is sooo much more friendly than some of the others ive visited thanks chaps
Re: 100ml jars ?
Don't get soppy on us y'big girl.
Re: 100ml jars ?
You know those GÜ pots with expensive desserts in them? Perfect cuts jars as they are 100ml to the top of the sides/bottom of the rim. We accumulated dozens of them thinking they might be good for something and now they are
Flump - Newcomer
Re: 100ml jars ?
Flump wrote:You know those GÜ pots with expensive desserts in them? Perfect cuts jars as they are 100ml to the top of the sides/bottom of the rim. We accumulated dozens of them thinking they might be good for something and now they are
Hi flump not sure what those pots are ,have you got a link to one at all ?
Re: 100ml jars ?
https://en.m.wikipedia.org/wiki/Gü Ask around friends and family and you might find a few. If not try Freecycle or Gumtree and you should find all you need for free.
Flump - Newcomer
