Soldering.
Re: Soldering.
Postby Capt-Cudellez » Sun Oct 23, 2016 2:23 pm
yes thats correct,
On a 42-22mm fitting reducer.....
the larger end has a 42mm OD that will fit inside a 42mm coupler
the smaller end is the same as a 22mm coupler and has a 22mm ID, and will take either a 22mm tube or a fitting reducer where the larger end is 22mm
Does that make sense?
Re: Soldering.
Postby Toper » Sun Oct 23, 2016 3:10 pm
Thank you very much Extremely helpful and probably saved me wasting my money.
T
Toper
Stills: Copper Pot Still
Re: Soldering.
Postby Easydrinker » Sun Oct 23, 2016 11:16 pm
I knew that I knew that, until so many questions.
Freaky that it made me question myself.
Re: Soldering.
Postby Dave » Mon Oct 24, 2016 1:56 pm
@Toper. I got my fittings from this place....
https://www.superdiscountplumbing.com/P ... E_FITTINGS
Lightening fast delivery, even if you choose the cheapest, which I did! ;)
Dave
Re: Soldering.
Postby Toper » Mon Oct 24, 2016 7:54 pm
Thank you Dave. With some slight modifications I got all that I wanted.
T
Toper
Re: Soldering.
Postby Toper » Wed Oct 26, 2016 3:32 pm
I did make a mistake in the end. Amongst other things, I ordered a 35mm x 15mm coupler and a 15mm x 8mm coupler, thinking they would fit together at the 15mm end. Unfortunately I should have ordered15x8mm reducer. I have now obtained the 15x8mm reducer locally and it fits well.
Two more questions.
1. When fitting a 6 or 8mm pipe should I drill the exact size of the pipe and rub the pipe down a bit or, drill half a mm larger, filling any gap with solder?
2. I note some parrots have the alcometer holder sitting slightly higher than the outlet bowl. I had assumed that this would simply be matter of pushing the body of the parrot up through the receiving bowl before soldering in place.. However, the lip in the coupler reducer prevents this. Am I overlooking a simple solution?
T
Toper
Re: Soldering.
Postby Dave » Wed Oct 26, 2016 6:08 pm
Not overlooking exactly, but you need to remove that lip to allow the other piece to travel through the fitting. Either file it away, or use a rotary dremel-like tool if you have one. I bought a Black & Decker version, they're sooo useful! 8)
Dave
Re: Soldering.
Postby Toper » Wed Oct 26, 2016 8:05 pm
Thanks for that Dave. More labour intensive than I had hoped, but definitely doable.
Any thoughts on the matter of the drilling for the 6/8mm pipes?
T
Toper
Re: Soldering.
Postby Dave » Wed Oct 26, 2016 9:33 pm
Toper wrote:Thanks for that Dave. More labour intensive than I had hoped, but definitely doable.
In practice, especially when using a hand drill, the hole tends to end up larger than the drill size, so, I'd use a size for size drill, and go from there. It's always better to take metal off than put it on! A nice tight fit is what you should be aiming for. Half a mm bigger is huge in relative terms,it's more than 10% of a 6mm pipe, and will result in what's known as a "piss fit"... :P
Dave
Re: Soldering.
Postby Toper » Wed Oct 26, 2016 10:00 pm
“...and will result in what's known as a "piss fit".”
Dave, this technical jsrgon really baffles me but I do take the point you make!! Cheers
T
Toper
Re: Soldering.
Postby Toper » Fri Oct 28, 2016 3:56 pm
Just finished my first venture into soldering. Suffering from two left hands when it comes to practical tasks like this, I am modestly pleased to have actually finished the task.
Thanks again to all who offered advice.
As mentioned previously I still did get confused when ordering my reducers and had to purchase a couple locally.
When starting to assemble, for soldering, I very carefully rubbed down the parts to be soldered and then forgot to put any flux on them before soldering.
Although I already had torch which look very similar to one of those suggested, I soon found that it appeared not to burn hot enough. I bought a better one from Screwfix.
Behold!
My apologies to all those artistic craftsmen who regularly show us their skills, but I have thoroughly enjoyed myself.
T
Toper
Re: Soldering.
Postby AFK@420 » Fri Oct 28, 2016 10:07 pm
Toper wrote:Just finished my first venture into soldering. Suffering from two left hands when it comes to practical tasks like this, I am modestly pleased to have actually finished the task.
Behold!
very nice job, not sure about the parrot but the anteater would be thrilled... ;D
AFK@420
Re: Soldering.
Postby Toper » Sat Oct 29, 2016 12:43 am
I take it then that a Turner Prize is out of the question?
T
Toper
Re: Soldering.
Postby Easydrinker » Sat Oct 29, 2016 1:17 am
Not sure of the correct point scoring language for that one, but I'll give it Neuf points.
Re: Soldering.
Postby Toper » Sat Oct 29, 2016 1:23 am
OK. So I can't sing either.
T
Toper
