100ml Syringe + PVC tube
http://www.ebay.co.uk/itm/Large-Big-Gia ... 25681dda64
I am crap at getting that last litre out of the ferment bucket when siphoning my wash.
Solution. I can siphon 23 litres off a 25 litre wash no problem. Then I decant the last two litres into a jar. When it settles I use my syringe to suck out another litre, giving me my 24 litres.
100ml x 10 only take 2 minutes.
I know its plastic, but its only 12-15% wash, and its not being used to store, just transport.
I love my syringe (NO! I do not use it for enemas), so I thought I would share.
Moz
mozr - Experienced Distiller
- Stills: Air Still
Re: 100ml Syringe + PVC tube
Nice idea! Plastic should be OK for wash strength anyway, just distilled product that might be questionable.
If you work it out roughly - if you get an extra litre at 15% out of each wash, then that's 4 batches to charge an AirStill and get probably 750ml at 45 - 50% out, so to all intents and purposes an extra bottle of vodka - it's paid for itself already!
Jimmy - Site Owner
You could try using a stainless steel icing syringe or a glass baster. Better still let your wet mash hang in a muslin cloth and collect over night in a pot and please don't squeeze the liquid out of the mash. Always leave a share for the Angels!!!
RickyRasper - Regular
- Stills: Copper Alembic Pot
Neat tip.
I already have a 100ml syringe, I use it to clean the airstill condensor tube. About 2 hours after the run is finished, I squirt 2 syringe full of hot water through the tube.
John51 - Senior Distiller
I have never cleaned my airstill tubes.
I must confess that my cleaning routine is not as rigourous as it once was.
Not made any difference either.
- Stills: Air Still
I never cleaned the tubes on my previous airstill. As it was sold as a water distiller there were no instructions with it.
After a lot of use it threw a hissy fit with loads of vapour and that was with the power at 160 watts.
During a run it would gurlge and the new (and proper) airstill didn't gurgle until the run after I forgot to clean the tube. Might be coincidence but now I take any gurgling to be a sign that the tube needs a good clean.
