Design Fault Perhaps
Info specific to the T500
Postby vino-tinto » Wed Dec 25, 2013 12:05 pm
I decided to strip down my T500 column to see if there is something I can improve, in doing so I found a design feature that could be effecting the refluxing.
There is a space, 3mm wide running all the way up from the water outlet to the top black cap between the copper pipe and the wall of the column, it is too narrow to be filled with sadles so therefore vapour must pass the packing, some will be cooled and return downwards, but there must be a percentage that gets past, IMHO, it could also cause a surge up this space if the packing is too tight.
I am going to wrap the pipe with SS scrubber that I pulled into a long strip before refitting it to see if this improves
vino-tinto
Re: Design Fault Perhaps
Postby vino-tinto » Sat Jan 04, 2014 5:03 pm
I have just completed a spirit run with the tube wrapped with SS scrubber and although I didn't get a higher ABV, I certainly got better refluxing.
I had to run at 61 - 63C to get an output whereas I used to run at 50C. I have done several tastes and in my opinion it is better, I'll leave for a couple of days then have another taste to see if it needs carbon filtering.
vino-tinto
Postby Voddy » Mon Jan 06, 2014 6:54 am
I wish you were my neighbour....
How would I go about stripping mine? Mini-Tutorial? (please!)
I'm very interested in your results and replicating them.
Thanks for your post - they are worth it's weight in ... neat alcohol! ;D
Voddy
Postby vino-tinto » Mon Jan 06, 2014 9:29 am
Voddy wrote:How would I go about stripping mine? Mini-Tutorial? (please!)
As requested
vino-tinto
Postby Icefever » Mon Jan 06, 2014 9:51 am
I said it before...a picture is worth 1000 words..Image
Now I know what's inside a T500...if you wanted to it would be so easy to make it up yourself.
Thanks VT...
Icefever.
Postby Voddy » Tue Jan 07, 2014 1:00 am
A super-thank you, vino.
Voddy
Postby vino-tinto » Wed Jan 15, 2014 10:50 am
vino-tinto wrote:I have just completed a spirit run with the tube wrapped with SS scrubber and although I didn't get a higher ABV, I certainly got better refluxing.
I can confirm that NO carbon filtering was necessary on the above.
Also there was NO smell left behind in the column (unlike ceramic saddles).
I have just completed another run with my mod + 2 copper scrubbers under the coil, the rest with SS scrubbers. I used a lentil wash, pieces of 8mm copper tube as boil enhancers and rapeseed oil as an antifoam.
The result was between 94 & 96% and on tasting, no carbon filtering is needed.
Without a doubt, a worthwhile mod ;D ;D ;D
vino-tinto
Postby fuf » Fri Jan 24, 2014 10:48 pm
Thank you Vino. It's my first day on here and the info is great. My T500 arrived this morning, I was thinking of not using the ceramic saddles and replacing them with SS scrubbers instead. It would be easier for me to do that instead of stripping the unit down. What do you reckon? ;D
fuf.... :
Nil illegitimi carborundum
fuf
Stills: T500 + SPP
Postby Capt-Cudellez » Sat Jan 25, 2014 12:00 am
Its a 5 min job - don't sweat it. I'd try it with the saddles first to set a baseline before you start trying to make improvements. Else how will you know if it is actually better.
Postby fuf » Sat Jan 25, 2014 12:34 am
[b Thank you for your reply. I trust you because you have tried and tested the T500, but as you suggest I will try the default setup first and post the results. The wash is bubbling with some gusto, but a week or so before I have a result.[/b]
fuf.... :
fuf
Stills: T500 + SPP
Postby Capt-Cudellez » Sat Jan 25, 2014 10:41 am
Ooops - I meant to hit quote, but edited your post by mistake. They shouldn't put those 2 buttons that close to each other - sorry for any confusion fuf. I'll fix the posts
Postby Icefever » Sun Mar 02, 2014 7:54 pm
I did read this post VT at the time...but did you ever decide to make or change that black plastic?? ;)
Postby vino-tinto » Sun Mar 02, 2014 8:03 pm
Icefever wrote:I did read this post VT at the time...but did you ever decide to make or change that black plastic?? ;)
No, I built a Boka instead, but once the warranty is out on the T500 I am going to re-craft a 54mm end cap to see if I can.
vino-tinto
Postby v4mpy » Sun Apr 05, 2015 1:20 pm
vino-tinto - my column has a silver water outlet which doesn't seem to budge.
Anyone managed to get the silver water outlet off thier column?
v4mpy
Stills: T500 & Airstill
Return to T500
