Water leakage
Info specific to the T500
Water leakage
Postby wingwong » Thu Jan 30, 2014 10:33 am
Hi, has anyone had any problems with water leakage from the thermometer probe housing???
wingwong
Re: Water leakage
Postby Spudnik1954 » Thu Jan 30, 2014 12:39 pm
I find that if my water pressure is too high it will leak around the temp probe just use a little less water.
Spudnik1954
Re: Water leakage
Postby vino-tinto » Thu Jan 30, 2014 1:09 pm
Wrap the probe with some PTFE tape
vino-tinto
Re: Water leakage
Postby wingwong » Thu Jan 30, 2014 3:31 pm
Many thanks, I cannot get my temp down any lower than 63 degrees as the water shoots out if I turn if up any more, any ideas, someone suggested blue tac but I'm unsure about this ???
wingwong
Re: Water leakage
Postby vino-tinto » Thu Jan 30, 2014 3:59 pm
Wrapping the probe with PTFE tape and then twisting it back in should tighten it up so that it doesn't leak.
vino-tinto
Return to T500
