Lentil Wash
Re: Lentil Wash
Postby Jaggie » Fri Jun 19, 2015 12:52 pm
ive had a Lentil wash fermenting since the 31 may i know i should be more patient but Dam! its still over 1.000 i guess i will give it a few more days then run it either way.
Jaggie
Re: Lentil Wash
Postby Easydrinker » Fri Jun 19, 2015 11:28 pm
@ Jaggie ,I would suspect low Ph is to blame here.You could drop a little Bicarbonate of Soda in there and see if the ferment speeds up,after the initial fizzing,to confirm.
@ black grouse,Man,if you were a child of mine,I would be shaking my head in despair!
By all means follow your own star,but stay safe.
Re: Lentil Wash
Postby black grouse » Fri Jun 19, 2015 11:30 pm
sorry, why is it unsafe?
black grouse
Stills: in progress.....
Re: Lentil Wash
Postby chill » Sat Jun 20, 2015 12:10 am
@Jaggie - pH strips from China are cheap and sufficiently accurate to diagnose issues such as this. I think that Robert is likely correct - the pH is low causing the yeast to become nearly inactive.
Re: Lentil Wash
Postby Almanac » Sat Jun 20, 2015 12:28 am
black grouse wrote:sorry, why is it unsafe?
Low Wines, the prodict of a single distilling run, contain too many volitiles to be healthy for you to consume. Take my word for it, single distilled wash is bad news for drinking. 8)
Re: Lentil Wash
Postby Anavrin » Sat Jun 20, 2015 12:59 am
@ black grouse
If your only single distilling I'm not supprised if gives you the shits!!
The art of craft distilation does not create alcohol, it removes alcohol more than anything to create a purer product, free from the esters and other chemicals produced during fermentation.
A single distilation or strip is just the first phase in cleaning up the alcohol you've fermented by removing it from the wash it was fermented in, it still contains many esters and chemicals you really don't want to be drinking.
It does however remove the majority of the alcohol from the wash, creating a clean base to make your spirit from.
A second distilation will further seperate undesirable fractions that are guaranteed to give you the shits/headache by producing them in an order that they can be removed or "cut" out of the clean drinkable alcohol (hearts).
I'll finish this post tomorrow when I'm not struggling to type!! 12 long days solid days at work followed by some home made is messing with my mind, but at least I won't have to worry about a hangover :)
Re: Lentil Wash
Postby black grouse » Sat Jun 20, 2015 8:44 am
Cool! Never knew lol :)
Means I now need to make much larger batches!!!!!
black grouse
Re: Lentil Wash
Postby Admiral Toad » Sat Jun 20, 2015 9:14 am
And the ferment goes on and on and on......
Admiral Toad
Stills: pothead, BP column
Re: Lentil Wash
Postby Mash » Sat Jun 20, 2015 9:42 am
black grouse wrote:Cool! Never knew lol :)
LOL. I do hope you mean large batches of better alcohol and not large batches of arse cannon propellant :D
Re: Lentil Wash
Postby black grouse » Sat Jun 20, 2015 10:19 am
Indeed :D
In fairness I dont get a hangover from what I've been doing, just the arse issues..... Should sell it as a diet drink!
black grouse
Re: Lentil Wash
Postby Mash » Sat Jun 20, 2015 11:11 am
DIET DRINK too funny (LMAO seemed the wrong response)
Re: Lentil Wash
Postby Jaggie » Sat Jun 20, 2015 2:08 pm
thanks for the PH information seems to have restarted it many thanks
Jaggie
Re: Lentil Wash
Postby Spirits4BB » Wed Jun 24, 2015 11:27 am
Lentil wash as now been in the fermenter for 17 days and is starting to clear and down to around 0998 from around 1090, and if I'm allowed to say being an inexperienced newbie it does taste and smells better than the Turbo yeast I used in the first wash... Now I know where your all coming from.... 8)
Any top tips to clear this to a usable standard? Finings or stick it in my lagering fridge and cool to around 4c to get the yeast to drop..?
For the next wash I've bought a Vodka star yeast and an Alcotec 24 Turbo Klar to try then I feel I've used more options for better experience.
S4BB :)
Spirits4BB
Stills: AirStill
Re: Lentil Wash
Postby Mash » Wed Jun 24, 2015 12:51 pm
Yes indeed - stick in your lagering fridge and cool to around 2-4c to get the yeast to drop.
Re: Lentil Wash
Postby Almanac » Wed Jun 24, 2015 6:58 pm
If using an Airstill the clearer the wash is before stripping the cleaner the final spirit will be. Using Turbo Klar should give you a good crystal result. I use Sparkolloid but it has to be imported from the U.S.
I've had washes stand on the concrete floor of my workshop during winter with the thermo in the wash showing 2oC and they wouldn't clear in a week and I'd end up having to use Sparky anyway ::)
You can run cloudy, no prob, but I think the result is better if the wash is cleared and it makes for a much easier post-run cleanup too ;)
Return to Recipes
