Refractometer Use
Refractometer Use
I've long had one in my kit but given it little use.
Always, always have trouble getting the damn hydrometer to settle in the test jar where i can easily read it. Finally got tired of it and having read on this site a while back, the ease of going refracto, decided that's it from here on.
Problem I've encountered, for some reason at times the delineation line gets a little blurred, fiddle with the focus to sharpen it up but there's always a 'grey' area.
Watched a doco last night on a fruit grower, showed him using one to gauge progress of his fruit and noticed he used it, to me, upside down - cover was on the underside whereas I'd only used it other way up.
So I tried it today, had beer and wine I needed to progress.......Upside down delineation line is sharp. So easy.
Purely for WIIW.
Purely for WIIW.
Re: Refractometer Use
What did you expect, you live in New Zealand
vino-tinto - Senior Distiller
VT you are a one....
Now you've done it.
Love a bit of kit, just ordered one
- Stills: s.s&t500 copper
Brilliant kit. Very good for starting. Get the right scale but use a hydrometer to finish.
I have two. One for sugar and one for alcohol.
Mine is alco !! do I need another???
I only have the one, I use my excel calculator for start and finish readings.
It compensates for alchohol contents in the final reading.
https://www.dropbox.com/s/6cs8twb6q3z34hn/Refractometer%20to%20Final%20SG%20Calculator1.xlt?dl=0
I have two because the scales are different and just make it easy.
1. Brix and potential alc. Upto 25%. I use this for starting fermentations.
2. Spirit. 10 to 100%. I use this for cuts.
The real gain is the speed and ease. You can do many tests till you get were you want. Literally it takes 5 seconds.
