Page 1 of 6
Posted:
Fri Dec 18, 2015 10:46 am
I have made Odin's gin a couple of times now. I have no real issue with it except ...
The gin seems to go off quickly if I make a 4 L batch. Ana the Juniper concentrations (quality of berries) seem to make a tremendous difference to the finished flavour.
It would be nicer to make smaller quantities of different flavoured gin.
Has anybody thought about putting just 2l in an Airstill and suspending the botanicals above it.
Thoughts please...
Would it work? Is it already been done?
Re: Airstill gin basket
Posted:
Fri Dec 18, 2015 3:05 pm
by hampk
I've thought about it, Mash. I only make a litre at a time so it's a bit less of an issue for me as it doesn't hang around when it's in the bottle.
The problem would be, I think, fabricating something that was sturdy enough to withstand the turbulence on the bottom of the still while not being able to use the rim as a hanger because of the seal. Unless you could contrive a ring with a second seal that sat between the lid and the base.. hmm...
Hampk
Posted:
Fri Dec 18, 2015 4:34 pm
by chill
I make 2L of
gin in my still all the time. I'd rather not say how often, but it does not go off...
I've thought of how to make a
gin basket, or rather have tried. The only two workable ideas I had was to put some sort of wire stand in the bottom to lift the botanicals above the liquid, or to run a thin wire though the outlet and hang it from that.
But there is no need to run the still with a full 4L, I have run it with less than 1L. I used to make
gin one bottle at a time.
Posted:
Fri Dec 18, 2015 5:14 pm
by wormwood
Mash wrote:I have made Odin's gin a couple of times now. I have no real issue with it except ...
Does your recipe include a fixative - angelica, orris, etc?
Posted:
Fri Dec 18, 2015 6:04 pm
Fixative... I use grains of paradise but seems to be not quite enough. Perhaps I am being tight and not putting enough in.
Contraption I had thought of was a sieve with 3 Legs. Top of sieve just below lid.
Has anyone had any success with this method?
Posted:
Fri Dec 18, 2015 6:48 pm
by chill
I think you are the only one I have heard refer to grains of paradise as a fixative. A flavouring yes, but you are certain they function as a fixative?
That contraption is what I had in mind, and in mind is as far as I have gotten.
Posted:
Sat Dec 19, 2015 5:04 am
I am liking this idea of jumping on a random/hijacked piece of kitchenware and putting it to use.
Grain's of Paradise?
Emperors new clothes as far as I'm concerned,Money best spent on more Juniper berries.
Posted:
Sat Dec 19, 2015 5:57 am
Stainless steel legs have been ordered from Ebay.
GOP - i am sure i read somewhere about it being a fixative. hmmm.
Posted:
Sat Dec 19, 2015 5:20 pm
by chill
GoP are an excellent change from black pepper on food. Not just for
gin!
I did a Google search for them used as a
gin fixative and came up empty, but I did not go too far down the page.
Posted:
Sat Dec 19, 2015 9:31 pm
by packapoo
Mash wrote:Stainless steel legs have been ordered from Ebay.
Sure it wasn't laxative?
Posted:
Sun Dec 20, 2015 1:43 am
I may be wrong, but consider my latest gin to be not so good due to GOP.
I certainly found the versions before GOP to taste better,
But that is taste, subjective and not objective.
Ain't it great that we all disagree?
Posted:
Sun Dec 20, 2015 7:20 am
Easydrinker wrote:I may be wrong, but consider my latest gin to be not so good due to GOP.
Do we need a fixative with little flavour impact then?
GOP seems to add a depth of flavour but maybe surpreses the high notes a little.
Laxative. Lol.
Posted:
Sun Dec 20, 2015 6:40 pm
by chill
Angelica and Orris Root are the traditional fixatives, I am sure there are others. Both add flavour but it seems to go well with the Juniper so I have been satisfied with them.
Posted:
Mon Dec 21, 2015 7:49 am
Thanks chill.
Do I need to add one or both and how much per liter please?
Posted:
Mon Dec 21, 2015 4:46 pm
by chill
I use both, mostly as I originally started with the ingredients listed on Bombay Sapphire. I believe either one will do. I use a small pinch of each for a 2L gin run (2L of 50% neutral into the still, makes 2 x 750ml bottles when run, cut, and diluted).
