Re: Brandy
My first 23lt batch of sav blanc has now finished fermenting, I was thinking of doing another one and runing them both together but I've decided to run just the one for now, I think I'm going to strip it using 1 plate, so a double distil and collect in 200ml jars noting the abv for each.
After deciding on my cuts I'll note the abv's for the hearts, each subsequent batch will be made following the same hearts cut, measured and collected using only the parrot abv but with recycled fients added to each batch from the last, I'm going to do 4 kits in total so this is getting quite expensive!! Even with a cheap wine kit its £28 a batch for the wine kit, £112 for 4 to give an estimated 8-10 litres!
Then I'll decide what to do with it before putting it on oak, I've always wanted to make some Port which is made by fortifing a half fermented red wine with un-aged brandy before aging the end result on oak, a bit off topic but here's a link to the Taylor's website about how they produce their port, it's intresting if you like Port and fancy having a go
http://www.taylor.pt/en/what-is-port-wi ... port-made/
