Page 2 of 24
PostPosted: Sat Oct 20, 2012 12:12 am
by chill
See the diagram on the last page. 30%.
PostPosted: Sat Oct 20, 2012 10:18 am
by Almanac
On the Spirit Runs the ABV is pretty unimportant. The cuts you make should be based on taste and smell only.
When I'm doing Spirit Runs I don't even use an alcometer to test ABV because it's irrelevant.
PostPosted: Sun Oct 21, 2012 10:39 am
by Frank
Firstly, and most importantly, thank you Aidanmac for putting into diagrammatic terms what is a challenging process (for newbies especially). IMHO, it is a great contribution to the fine art of distilling as we know it and thank you too for predecent 'contibutors' here too.
I'd make the observation that the posted methodology holds true regardless of wash, it is basically the ABV/volumes that may vary...and I am now quite sure that there are certain other washes that provide the opportunity for a higher quality distillate than sugar-based 'turbo yeast' ferments....
eg partial grain or wheatgerm/liquid malt extract for instance.
I offer this as food for thought only and in no way wish to discount this thread.... to each their own. ;)
PostPosted: Sun Oct 21, 2012 7:23 pm
by Robbo79
Hey guys how long is a stripping run taking you to get to the 1350ml ?
PostPosted: Sun Oct 21, 2012 8:45 pm
by knobby
Hi Robbo, and welcome.
It takes on average to 3hr 35 mins to do a stripping wash
PostPosted: Sun Oct 21, 2012 8:47 pm
by knobby
Air still results
SG 1.090
FG 0.980
Wash - 14.19%
Stripping run
100ml 68%
200ml 65%
300ml 63%. 1hr 28mins
400ml 60%
500ml 56%
600ml 52%
700ml 46%. 2hrs 12 mins
800ml 41%. 2hrs 24 mins
900ml 33%. 2hrs 36 mins
1000ml ?????
1100ml 15%. Overall 46%. 3hrs
1200ml 11%. 3hrs 13 mins
1300ml 7%. 3hrs 27mins
1350ml. Overall 40%. 3hrs 35mins
Spirit run
50ml foreshot discarded 1hr 7 mins
HEADS
250ml heads kept to one side. 1hr 26
HEARTS
100ml. 77%
200ml. 76%
300ml. 75%
400ml. 75%
500ml. 74%
600ml. 73%
700ml. 70%
800ml. 68ml
900ml. 66%
1000ml. 62%. 2hrs 47mins. Overall 70%
TAILS
250ml. 55%
100ml. 46%
100ml. 35%. 3hrs 34 mins
These are my results and will differ slightly depending on your original wash and strength, all with the help of Mozrs diagram
PostPosted: Mon Oct 22, 2012 5:00 am
by chill
Robbo79 wrote:Hey guys how long is a stripping run taking you to get to the 1350ml ?
Don't think about the amount collected. Think about the ABV. When the total result collected gets down to about 45% ABV, there is not much less to extract. The time that takes varies with the wash.
PostPosted: Tue Oct 23, 2012 7:54 pm
by Robbo79
thanks guys. do you still filter after 2nd run or is this not needed now?
PostPosted: Tue Oct 23, 2012 8:23 pm
by Magnu420
Robbo79 wrote:thanks guys. do you still filter after 2nd run or is this not needed now?
when i did my spirit run i filtered mine
PostPosted: Wed Oct 24, 2012 6:46 am
by Almanac
My experience has been that all spirit from the Airstill benefits from serious Activated Carbon filtering. Having said that the 'filter' that comes with the Airstill is pretty useless for the purpose.
PostPosted: Thu Nov 22, 2012 5:02 pm
by Robbo79
Guys, im confused, i only seam to get 5 strip runs out of my wash, also a strip run once collected 1350ml give my 40% so im only adding a little water to bring this to the 30% ready for the spirit run, in do ing this im only able to collect a total of 2 Gallons ready of stripped low wines at 30% ready for 2 runs through the still, as to the 3 on the flow diagram, how am i so far out?
PostPosted: Thu Nov 22, 2012 6:43 pm
by chill
Sounds like your wash has less than the 14% that those amounts are based on. How much sugar are you using? How much water? Are you sure it has finished fermenting? It should taste slightly sour like white wine, not at all sweet. Also to get six strip runs, you need to have 24L of liquid left after fermenting, clearing, racking off etc.
PostPosted: Thu Nov 22, 2012 7:15 pm
by Robbo79
im using 6kg sugar, and following the tripled distilled turbo yeast packet. Its fermented out as i leave for 14 days before clearing.
PostPosted: Fri Nov 23, 2012 10:10 am
by John51
Isn't the guide based on 20%?
PostPosted: Fri Nov 23, 2012 5:22 pm
by chill
I was thinking of Mozr's breakdown, which is what I started with. It is based on 14%. Aidan's is based on 7Kg of sugar in 26L, so 15.8% by my calculations. I'd be surprised if anything gets you 20% without off smells. For the yeasts that I use (note, EC-1118 not VodkaStar which we don't get over here), 14% is as far as I want to push it.
