possible cornmeal sourmash
Postby Corps012588 » Thu Mar 24, 2016 4:19 pm
Hi guys.
Does anyone know if cornmeal would be suitable to
Try and do a kind of uncle jesse's sour mash with?
If so any hints or tips regarding amounts in a 25ltr fermenter
Would be greatly appreciated.
Also would a handful of raisins suffice as nutrients?
I'm going to be trying Mauripan yeast for the first time too.
Thanks in advance
Corps012588
Re: possible cornmeal sourmash
Postby Corps012588 » Thu Mar 24, 2016 4:21 pm
Oh I forgot to mention I will be using a smartstill
Corps012588
Postby Benoit » Thu Mar 24, 2016 5:30 pm
Be very careful with your water temps, that stuff is ground fine & I believe partially cooked so if you go with hot water to dissolve the sugar then you risk adding the cornmeal & turning it all into wallpaper paste.
Postby chill » Thu Mar 24, 2016 5:48 pm
It won't turn into paste that quickly. I've used cornmeal for this and for mashing with enzymes. It takes quite a bit of head to get it to gelatinize. The only problem you will find is separating it from the wash when you rack it off.
Postby Easydrinker » Fri Mar 25, 2016 1:28 am
I would say that a handful of chopped or minced raisins, with the cornmeal, and sugar would suffice the yeasties.
Postby Corps012588 » Fri Mar 25, 2016 7:24 am
Thanks guys. Basicaly all im after is something which tastes of corn sfter being
Going through the still twice. I had considered cracking some popcorn kernals and trying that.
any thoughts?
Corps012588
Postby chill » Fri Mar 25, 2016 2:19 pm
Different taste. Use the corn meal. Or corn flakes, but that is yet another different taste.
Postby Easydrinker » Sat Mar 26, 2016 12:26 am
Corps012588 wrote:Thanks guys. Basicaly all im after is something which tastes of corn sfter being
any thoughts?
OK, popcorn made me smile :) , would never have considered that as an option, if you try it please report back, I suspect the little buggers would float for a week or two...
A couple of years back I did some sweetcorn trials, the results should be posted in the recipe section here.
It tasted OK,but I don't recall any significant corn flavour coming through.
HTH
Postby chill » Sat Mar 26, 2016 6:46 am
I perceive it as a sweetish, grainy taste. It does not taste like sweet corn, but I can discern between it and a barley based wash. Corn flakes wash tastes like, well, breakfast cereal. It is not bad but not bourbonish. With some JD chips and nuking it can be an interesting drink. I should make some again, it has been years.
