It's Arrived! Still Dragon Torpedo
Postby Anavrin » Thu Oct 09, 2014 8:19 am
Hi guys, got my Still Dragon 2" -4" Torpedo today and I must say it's very impressive bit of kit, here's some pics
It uses 2" tri-clamps top and bottom with a 4" clamp in the middle, I was thinking of stacking them when I can afford another but the next one will be a full 4" section that can be fit in between the 4" middle
Re: It's Arrived! Still Dragon Torpedo
Postby YHB » Thu Oct 09, 2014 8:55 am
It's so --- Shiney!
Looking forward to reading the reports.
Postby vino-tinto » Thu Oct 09, 2014 12:55 pm
Very nice, by the way my granny's got a table cloth like that.
vino-tinto
Postby Easydrinker » Thu Oct 09, 2014 3:41 pm
It looks much better in your pics than on their website.
Best of luck.
Postby Almanac » Thu Oct 09, 2014 7:07 pm
Wow!Image.....I mean...Wow!Image
Nice one 'A' ....Wow! Image
I'm closing my mouth now, the wife says I look sillier than usual....Wow!Image
Postby Fil » Thu Oct 09, 2014 8:18 pm
PHOOAARRRR!!!! real life stilling porn luverly ;)
whens it gonna see some action? i hope you can post a pic of the good stuff bubbling away on the plate. ;D
Fil
Postby packapoo » Fri Oct 10, 2014 3:46 am
aidanmac wrote:Wow!Image.....I mean...Wow!Image
Now there's an idea AM....2 sight glasses on one torpedo.
Postby Anavrin » Fri Oct 10, 2014 8:21 am
Just had to stick it on to see what it looks like
I've got a wash to strip at the weekend, then I'm gonna fit it and pack the column for a spirit run, will be interesting to see how it performs
Postby ant » Fri Oct 10, 2014 11:49 am
That is very nicely made. I am sure you will love the performance.
ant
Postby Capt-Cudellez » Sun Oct 12, 2014 7:43 pm
Really nice, I got one of the original copper ones, and love it to bits. The window will start to fog before your thermo gives indication that tails are approaching - its like an early warning system.
I like the bigger windows that yours has too.
Postby Anavrin » Sun Oct 12, 2014 8:47 pm
I'm running it for the first time tonight, all I can say so far is this is looking the best run I've ever done! I changed my normal Racshig ring packing for 1M of SS scrubbers.
I had 20lt of strip to start with that I added 10lt of water to, so 30lt at just over 30%
I took 200ml fores
Almost a litre of heads on my Boka output, the output from the plates suddenly slowed and the temp increased a little so I called that the heads and switched to the VM output for the hearts collection, I also found I could run it at a higher take off from the boka output than before.
So far it's been rock solid for a couple of hours, I've collected 3.5lt at 94% and it's showing no signs of letting up, I'm collecting 1.2lt per hour, 250ml at a time in 500ml kilner jars, I'm gonna run out of jars soon!!
Postby Easydrinker » Sun Oct 12, 2014 9:50 pm
You are probably done right about now.
Really hope it did all that you hoped for.
And thanks for sharing.
Postby Anavrin » Sun Oct 12, 2014 10:07 pm
Still going, got just over 5 lt so far!
This is crazy, 21 - 250 jars, plus a litre of heads/fores and no sign of tails!!!
Postby Easydrinker » Sun Oct 12, 2014 10:21 pm
Well done you.
You know that we expect a full report when you have the time?
Postby Anavrin » Sun Oct 12, 2014 11:00 pm
I'm getting bored now! Got work tomorrow and an early start, I now have 6lt, it's still 94% and still coming at exactly the same rate and the temp is still rock steady!
