Turbo Carbon
Turbo Carbon
Postby Superslim007 » Fri Jun 14, 2013 1:24 pm
Hey
Looking for advice on turbo carbon
Does it work?
Is it worth using?
SS claim it helps to remove dead yeast cells and unwanted flavours
What do you guys think ??
Live Long and Prosper !!
Superslim007
Stills: SS T500
Re: Turbo Carbon
Postby YHB » Fri Jun 14, 2013 5:10 pm
I do not think that the carbon in the wash is a system favoured by many here.
It is all part of system to get the maximum amount of Alcohol in the minimum time at the sake of quality. If thats what you need then go for it, but there are lots of other options.
I am sure that the carbon does help in getting rid of some unwanted flavours, but where do the unwanted flavours come from? - The turbo yeasts.
So if you use a system that does not push the yeast too hard, you will not get the unwanted flavours therefore you will not need the carbon.
Re: Turbo Carbon
Postby Superslim007 » Fri Jun 14, 2013 5:18 pm
Thanks YHB
What would you recommend for a 25l sugar wash?
Superslim007
Stills: SS T500
Re: Turbo Carbon
Postby Gaztops » Fri Jun 14, 2013 5:46 pm
I use 75g of Allinsons Dried Active Bakers Yeast 64p from Asda or Tesco (It's in a yellow Tin)
I Don't Drink Too Much, I Just Drink Enough.
Gaztops
Stills: Pot Still / Liebig
Re: Turbo Carbon
Postby Superslim007 » Fri Jun 14, 2013 7:06 pm
What about nutrients ?
Superslim007
Stills: SS T500
Re: Turbo Carbon
Postby Gaztops » Fri Jun 14, 2013 7:45 pm
This the recipe I use for a 25 litre sugar wash
5kg sugar
200g tube of tomato puree (this is the nutrient)
Juice of 1 fresh lemon
1/4 teaspoon of Epsom Salts (Andrews Salts can be used as an alternative)
75g Allinsons Dried Active Bakers Yeast (Asda of Tesco's, it's in a Yellow Tin)
Gaztops
Re: Turbo Carbon
Postby Uber » Fri Jun 14, 2013 8:23 pm
Gaztops wrote:This the recipe I use for a 25 litre sugar wash
5kg sugar
I run the same wash. It ferments almost as quick, and is also much cleaner tasting than a turbo based wash. (And much cheaper too)
This is a good calculator to work out different sized ferments: http://shuggo.com/birdwatchers/
No carbon or clearing additive needed.
Uber
Stills: AirStill,2" Pot
Re: Turbo Carbon
Postby YHB » Fri Jun 14, 2013 8:39 pm
Try this post for nutrients for a sugar wash.
viewtopic.php?f=2&t=663
Re: Turbo Carbon
Postby Superslim007 » Fri Jun 14, 2013 8:57 pm
Thanks guys ill give them a whirl ;D
Superslim007
Stills: SS T500
