Re: Me running my T500
Hi Fuf, if you have collected 3L, and you have put everything bar the first 150mls through the filter you are definitely consuming heads. And depending how much alcohol was in the boiler to begin with, there are probably some tails in there too.
Dont get me wrong, what you have made is no worse for you than what you buy in the shops, but it is possible to do better by making a slightly narrower cut.
This seems wasteful at first, but you get most of the alcohol back by throwing the parts that don't make the cut in with the next boiler charge.[/quote]
I ran the whole lot including my second run through the still again, watered down to 25 ABV. I discarded the first 350 ml and let it run for about 6 hours at 50c. Total yield was one gallon @93 ABV and did not bother with collecting all the tails as my demijohn was full.
All watered down to 40 ABV, that gave me 16 pints and it's quite smooth
I reckon it's double distil from now on, but I'm on a learning curve at the moment and things will evolve
