heads ?
• Page 2 of 3 • 1, 2, 3
Re: heads ?
I do the same strip with the pot full power down
to 97c or about 30% then with 2 or3 strips diluted
to 30% then spirit run with the column.
I personally like the AS for gin good quality and
good for 2ltrs almost unsupervised.
- Stills: s.s&t500 copper
Re: heads ?
Setting myself up to be shot down in flames here.
I see no problem using an Alembic for gin and your thoughts on cuts makes sense.
I don't have a T500.
I can go along with not finding tails in a spirit run, chances are that you lost them by not going too far into the strip runs, and the remaining ones seem to be left in the boiler on a spirit run.
I believe that this is what happens with my neutral runs.
I run very different stills, but always strip with a pot head and spirit run neutral with a packed column.
I started this way because of common experience/knowledge.
My understanding is that strips should happen fast, and reflux slow.
One through an empty column and the other through a packed one, for those that can.
Now, if Myles would like to find the time to jump in and tell me where I have this wrong, I am all ears.
Re: heads ?
Robert, is it faster to use a pot still for the stripping run then?
Thunderbird - Regular
Re: heads ?
It's a lot quicker to strip on my pot head also on my setup I can use a lot less water.
Another benefit is the column packing does not get smelly as quickly as it would using it constantly
Brewhunter - Senior Distiller
- Stills: T500 + Airstill
Re: heads ?
Brewhunter wrote:It's a lot quicker to strip on my pot head also on my setup I can use a lot less water.
What is your setup Brewhunter? The SS instructions for the reflux column say to adjust the flow between 400 - 700 ml/minute whereas the alembic says 2.5 litres/minute over 3x as much. What am I missing here or rather what is it you are doing to conserve water?
Re: heads ?
Thunderbird wrote:Robert, is it faster to use a pot still for the stripping run then?
Absolutely. Quicker still to freeze it!
Re: heads ?
Thunderbird wrote:Brewhunter wrote:It's a lot quicker to strip on my pot head also on my setup I can use a lot less water.
Yes the still spirits alemic setup is very wasteful.
On my t500 I have a much larger and more efficient condenser which Myles built for me, it only needs a very small amount of water.
Re: heads ?
Good mood lighting.
Re: heads ?
Am very tempted to say something Mash.
Re: heads ?
Mash wrote:Good mood lighting.
Mood lighting? lol
Re: heads ?
like wise with the wife BH she could scare the local thugs.
Re: heads ?
Wow, that’s nice Brewhunter. As a mere mortal though I think I’ll have to stick with my original plan of attack as I don’t have that lovely setup.
Re: heads ?
I suggest that you read between the lines of some of the old comedians here and follow the path that seems to suit you.
Re: heads ?
Yup.
Jocularity aside. Regardless of the type (and BH's is a nice thing, but I wouldn't say it out loud) A pot head should be quicker. IMO Setup properly you should get a greater vapour flow to the condenser - quicker. And a quicker startup. Very popular for people to setup 2 easily interchangeable rigs. A dedicated stripper and a separate column for spirit runs.
Gins IMO want a pot head - you are adding flavours not looking to restrict them.
Re: heads ?
Mash wrote:Jocularity aside. Regardless of the type (and BH's is a nice thing, but I wouldn't say it out loud) A pot head should be quicker. IMO Setup properly you should get a greater vapour flow to the condenser - quicker. And a quicker startup. Very popular for people to setup 2 easily interchangeable rigs. A dedicated stripper and a separate column for spirit runs.
So Mash, are you saying that even with the SS alembic setup I should be able to do a stripping run quicker than with the reflux column? I'm open to experimentation but if I'm going to waste a huge amount of water (especially in this weather plus I'm metered) I think I might stick with the reflux column for now. But if water usage would be about the same due to the time saving I might give it a try.
Gins I usually make using the Airstill but it's so time consuming. Now I've found recipes I like I'd like to be able to make them quicker, hence I bought the alembic dome and condenser (I also want to try making whisky).
