Page 2 of 3
Re: Alembic copper dome and condenser has arrived!!!!
PostPosted: Sat Apr 09, 2016 10:47 am
by m314
I like to keep an 8 gallon bucket free, one wide enough for the copper dome to fit inside. Do your stripping runs first. Before the spirit run, put the dome and copper arm (separated) in the bucket. Fill with water and a few teaspoons of citric acid and let it sit overnight. The next day, scrub the inside of the dome with an abrasive sponge. It will be clean shiny copper again with almost no effort. :)
It makes a difference in quality in the second distillation when everything is clean. You'll be surprised how black the copper gets after a few stripping runs.
PostPosted: Sun Apr 10, 2016 12:01 am
m314,
For a new poster, I have to say that you post sage stuff. Respect.
Please keep it up and stick around.
Newcomers to this site are just as worthwhile as people that have posted ten times a day for the last few years.
Quality over quantity every time,spirit run or post count ;)
PostPosted: Sun Apr 10, 2016 12:18 am
by Seagull
Thanks m314 Anything that saves effort is fantastic! :)
PostPosted: Sun Apr 10, 2016 10:01 pm
by m314
This is what I was talking about. The copper gets dirty after a few stripping runs.
http://imgur.com/9rZmjqd
This is what I've got after 5 stripping runs from my latest rum batch. :)
http://imgur.com/HcdHxWN
I might actually need to to do two spirit runs this time.
PostPosted: Sun Apr 10, 2016 10:15 pm
by m314
I have no clue why there was a clean coppery looking area in the first pic. This is what it looks like soaking in water and citric acid.
http://imgur.com/IY9ASr0
Where did the clean patch go? Is it still there but not visible now somehow? The world may never know the answer to this question.
PostPosted: Sun Apr 10, 2016 10:18 pm
What I struggle with here is that for me, anything copper comes from a strip run cleaner than it started, a boil piece or a glance up the column.
After a spirit run they are black and gunky.
I can sit boil pieces in citric acid and clean them up, and a spirit run will still make them as dirty as FCUK.
Are we at odds here?
PostPosted: Sun Apr 10, 2016 10:50 pm
by m314
I don't have a full understanding of what happens to copper in the distillation process. This particular copper dome gets blackened and dirty after a few stripping runs with rum wash. It gets nice and shiny again after soaking in citric acid with some mild scrubbing the next day.
I clean it this way before and after the spirit runs. The results from a spirit run turn out better when you start with nice new looking shiny copper.
PostPosted: Mon Apr 11, 2016 2:35 am
Not wishing to argue with you, but don't you find the copper dirtier after a spirit run than a strip?
PostPosted: Mon Apr 11, 2016 3:10 am
by m314
I'm actually not sure. I usually do 4 or 5 stripping runs in a row. The copper dome gets pretty dirty by that point. I soak and clean the dome at that point and after the spirit run.
It probably also depends on what you're running. Boiling 6 gallons of thick black rum wash (molasses and sugar) seems to make it dirtier than a light colored wheat germ / sugar wash.
PostPosted: Mon Apr 11, 2016 4:47 am
by Myles
It does sound to me like you are over cleaning. The only time the inside of the copper should be bright shiny 'raw' copper is from a deep clean after soldering.
This removes flux, solder residue etc and leaves a bright unoxidised raw copper surface. This is not good and the first alcohol run through this will taste metalic.
You do need to clean off deposits and residue but you WANT to leave an oxidised patina on the inner surfaces of the copper.
Most of the time I just steam clean my gear now and then. Possibly a weak acid wash but definitely no physical abrasion to get back to a raw copper surface.
PostPosted: Mon Apr 11, 2016 7:12 pm
by m314
What is the disadvantage of having clean copper? My spirit runs have turned out better when I start with clean copper. I never noticed metallic tastes in the final product.
PostPosted: Tue Apr 12, 2016 4:44 am
by Myles
Might be terminology.
Clean is good, but clean and oxidised is better.
Raw metal (pinkish colour) like you get after a deep clean with acid is not good, and can leave off tastes in the product. The copper oxide layer protects the surface of the copper and still allows it to do all the good work.
Try doing your usual clean then do a spirit run. Then just rinse and clean off the deposits over the next few runs and allow the copper to form a patina. Then do another spirit run and compare the products.
You will probably notice a difference.
PostPosted: Sat Oct 15, 2016 9:31 pm
by Brewhunter
Very nice, I'll be on the look out for one soon
PostPosted: Sat Oct 15, 2016 11:13 pm
by Curmudgeon
I think the condenser is good value, but would struggle to justify the cost of the copper dome.
PostPosted: Sun Oct 16, 2016 7:22 am
by inspector gadget
brewhunter wrote:Very nice, I'll be on the look out for one soon
Sranger than strange, I was looking at these just last week... ;D must resit the temptation for more copper just yet lol
