Kay-5 sanitize
Kay-5 sanitize
Postby Corps012588 » Mon Sep 29, 2014 10:59 am
Hi all. I can get hold of loads of sachets of key-5 sanitizer and just wondered if anyone uses it for sterilising their equipment .
Corps012588
Re: Kay-5 sanitize
Postby Fil » Tue Sep 30, 2014 9:41 pm
I had to google it. as its chlorine (bleach) based you would need to rinse it well (3 times) to clear all residual.
you cant beat 5star starsan imho, cheap as chips as a bottle should last 5+years before you need more. due to its persistent nature you can mix it up and apply via a trigger spray bottle, and use 1l for a good few brews, a cheap book of indicator paper strips is all you need to test the mix after a few months and as long as its ph3 or less its good to go,
http://www.the-home-brew-shop.co.uk/aca ... CskBfldWac
not endorsing the shop just the first link google kicked up
Fil
Re: Kay-5 sanitize
Postby Magnu420 » Tue Sep 30, 2014 11:25 pm
I use videne to sterelise my cornies and fermenting bins
1.5ml to a 1ltr water also got it from chemist about £7
Magnu420
Stills: Airstill + half boka
Re: Kay-5 sanitize
Postby YHB » Wed Oct 01, 2014 2:55 am
I use this for long time storage of empty fermenters demijohns etc.
Similar to Milton but a third of the cost.
A pound for a litre in the discount chemist chains.
Re: Kay-5 sanitize
Postby Magnu420 » Wed Oct 01, 2014 8:53 am
YHB wrote:I use this for long time storage of empty fermenters demijohns etc.
also you can get this from poundland. poundworld. or 99p shops
Magnu420
Re: Kay-5 sanitize
Postby Anavrin » Wed Oct 01, 2014 9:29 am
I've always use good old VWP :-)
The guy in one HBS told me starsan is a good sanitiser but it doesn't clean anything, so you still need something to clean with first before using it, taking twice as long.
VWP does both, it is expensive but in my experisnce works perfect at 1 teaspoon per gallon.
Re: Kay-5 sanitize
Postby John51 » Wed Oct 01, 2014 1:12 pm
Apart from making up the wash and pouring it out etc. I keep the lid and airlock on my fermenters. While the T500 is warming up, I rinse out a fermenter with cold water. Takes about 3 goes of swirling water around to get a clean fermenter. Then I make up the wash.
I'm not sure that I'd be this lax if making a regular wine but the VS ferment looks strong enough to kill any nasties still there after the rinse.
John51
Re: Kay-5 sanitize
Postby Easydrinker » Wed Oct 01, 2014 11:44 pm
I'm guessing that this is one of those personal things,in that if it has always worked for yourself,then that is good.
Myself,if immediately re-using a fermenter,I simply wash/rinse and re-use.
Discovered the hard way that if not,then simply storing after a wash/rinse leads to furry stuff growing.
Keeping it simple,and low cost,I now wipe such offending articles with household bleach,and rinse.
My reason?
4 years ago I sat in the dentists chair for 3 straight hours having a jawbone graft,not pleasant.As they waited for me to become normal-ish, they started cleaning up the room,as always,with the cheapest household bleach.
I asked.
They replied why not?
My jaw healed,I have a lot of faith in such simple practise.
I would like to think that we haven't hi-jacked your thread,merely moved it along,even if non of us actually answered your original question!
Re: Kay-5 sanitize
Postby Corps012588 » Thu Oct 02, 2014 1:55 pm
Not at all. This is all very interesting to read and glad your jaw healed well
Corps012588
Re: Kay-5 sanitize
Postby Boozoid » Thu Oct 02, 2014 2:02 pm
I use home bargins 99p sterilising tablets.Sodium Dichloroisocyanurate a bit more expensive than bleach but at least I know the strenght of it.
I also use starsan, when brewing beer.. it's so easy to use
Boozoid
Stills: Boka and potstill
Re: Kay-5 sanitize
Postby John51 » Fri Oct 03, 2014 10:02 am
Adding for clarity: When I syphon off the wash, there is an inch or so of wash/sediment left. I leave it like that which may be the reason I have no problems rinsing out when needed.
John51
Re: Kay-5 sanitize
Postby Aethelstan » Fri Oct 03, 2014 11:51 am
I used to use the tablets from HB, but now I just use Wilkos functional household bleach. It's cheap enough to fill my 80l plastic box with, which allows me to fully immerse my pressure barrels, fermenting buckets, demijohns, bottles etc. I probably use it too liberally though.
Aethelstan
Stills: Heath Robinson
Re: Kay-5 sanitize
Postby Almanac » Sun Oct 05, 2014 9:07 am
I use Milton, diluted as per instructions, and kept in a spray bottle but I only sterilise immediately before using a fermenter. Keep it simples peoples ;D
