heaters
heaters
Postby beerbeermorebeer » Sat Dec 06, 2014 3:47 pm
hi all, im thinking of getting a fishtank heater but i dont know how big to go.
does anyone use a FT heater and if so, how big ( in watts) is it
or if anyone uses a different type of heater, then id like to know
beer.
beerbeermorebeer
Re: heaters
Postby alan » Sat Dec 06, 2014 6:37 pm
Hi beer I use couple of heaters one is a fish tank type heater 75 watts thee other is a belt heater.
alan
alan
Stills: airstillT500 2in ph
Re: heaters
Postby Toper » Sat Dec 06, 2014 7:23 pm
I have some fish tank heaters.. They are 25w “FISH R FUN” Aquarium Heaters and capable of handling up to six gallons at a set temperature, ranging between 16 – 32°C.
They cost about £10.00 each.
T
Toper
Stills: Copper Pot Still
Re: heaters
Postby fuf » Sat Dec 06, 2014 7:55 pm
I use an Aquarium Heater, http://www.ebay.co.uk/itm/Hidom-Submers ... 3a7cda2901
Works just fine.
fuf.... :
Nil illegitimi carborundum
fuf
Stills: T500 + SPP
Re: heaters
Postby beerbeermorebeer » Sat Dec 06, 2014 8:16 pm
fuf wrote:I use an Aquarium Heater, http://www.ebay.co.uk/itm/Hidom-Submers ... 3a7cda2901
Works just fine.
they'r cheap enough.
beerbeermorebeer
Re: heaters
Postby Easydrinker » Sun Dec 07, 2014 12:43 am
I have a bunch of these;
http://www.ebay.co.uk/itm/Submersible-A ... 20f13d0587
they seem to work well enough until I get clumsy.
£6.49,posted,cheap as chips. My brewing done in 18°C ambient,uninsulated 25 litre vessels.
HTH
Re: heaters
Postby beerbeermorebeer » Sun Dec 07, 2014 7:24 am
cheers lads..
i think il order a 75watt one.
beerbeermorebeer
Re: heaters
Postby John51 » Sun Dec 07, 2014 3:20 pm
Check the max temp first with plain water (same volume as the wash) and a separate thermometer. It can happen that the temp goes way higher that what you would like before the thermostat switches off and that can kill the yeast.
John51
Re: heaters
Postby Toper » Sun Dec 07, 2014 4:55 pm
The use of thermometers to check thrmometers reminds me of the old adage, “qui observat vigilum”, or as Juvenal has it in his Satires, “ ..Quis custodiet ipsos custodes? .
Not that I'm not in agreement with the suggestion. Indeed, one of the first things I do with any such equipment is to check it against something I already feel I know is accurate.
T
Toper
Re: heaters
Postby beerbeermorebeer » Wed Dec 10, 2014 5:35 pm
50watt heater came today... absolutely perfect for the job and very compact too
beerbeermorebeer
