Page 2 of 2
Re: new still
Posted:
Fri Jan 02, 2015 1:02 am
by Anavrin
I wasn't sure when I first seen your setup how it would work but now I'm liking it a lot with the seperate columns and drains, when I add more plates to my setup I might go down the same road with a seperate packed column
Re: new still
Posted:
Wed Apr 22, 2015 11:10 pm
by googe
Sounds good anavrin!. just realized I havnt updateD this in a while lol. Have done lots of runs now and very happy with it!, Also did some speed testing, rum at 90% at 3.7lph, and neutral at 96% at 4.2lph.
Re: new still
Posted:
Wed Apr 22, 2015 11:12 pm
by Rockchucker
Its all shiny now Googe, looks great!
Re: new still
Posted:
Wed Apr 22, 2015 11:14 pm
by googe
Re: new still
Posted:
Sat Apr 25, 2015 6:00 am
by Myles
Anavrin wrote:Hi googe
Can I ask what the diameter of your main columns are in mm?
SD have brass 4 inch easy flange's, they state there for 105mm copper but The closest I can find is 108mm which is too big
Anarvin, sorry i forgot about this. I checked the 4" brass ferule dimensions and the outer dia of the socket part is the same diameter as the outside of the 108mm tube. If you cut a 2" length of 108mm tube and cut out a slither so it fits inside the copper tube, that bit will now fit just right inside the ferrule. Have 1" in the ferrule and 1" inside the copper tube.
Re: new still
Posted:
Sun Apr 26, 2015 10:43 am
by Frank
cmon Googe
96%!!!! I mean
really
mate, great build, topnotch results, congrats (again)
Re: new still
Posted:
Mon Apr 27, 2015 1:45 am
by googe
Thanks sp!. Not my doing frank, I just turn the heat on and watch lol. Thanks though mate!
Re: new still
Posted:
Tue Apr 28, 2015 3:00 pm
by Spirits4BB
That looks fantastic............
Re: new still
Posted:
Sun Jun 21, 2015 12:14 pm
by ant
That is an impressive build. Good to look at and more importantly good functional versatile design. Hight problem? What hight problem? Well done.
While doing multi column why not a small LM first column to compress and remove heads without them ever reaching the rest of the still? Or would that just be superfluous with the way it already runs? 96% neutral is top notch. Puzzled why that ran faster than the 90% though?
Re: new still
Posted:
Wed Jun 24, 2015 10:04 am
by googe
Thanks ant. A small lm before would be counter productive. If you add a packed section to plates, as if you added extra height to an existing column, you'll get more speed and higher purity.
Re: new still
Posted:
Thu Jun 25, 2015 1:07 pm
by ant
Yes I get that. That is why I made a bubble ball to go under SPP.
I may have missed the exact configuration you used on each run to explain why the 90% was slower. I'll reread.
Why would an LM be counter productive? People rave about it's unrivalled heads compression. Seems to be it's best feature after easy to make. I get the extra stage would slow things down but is it worth that to mimimise your losses to heads?
Re: new still
Posted:
Thu Jun 25, 2015 1:13 pm
by ant
Ah of course. You just use the plates for rum. Both for neutral. Silly me. Didn't think that through the first read.
