Page 2 of 2
Re: Freeze Stripping
Posted:
Tue Jun 12, 2018 6:43 am
Are many people freeze stripping?
Posted:
Tue Jun 12, 2018 10:00 am
by Goog
I had a go at it with 10lts of TPW last week as an experiment, after I thawed out my bid orange icy pole I ended up going with a strip run. I am not ruling out having another go but might wait until I got the process of stripping and spirit runs down a bit more first. Still learning and trying so all good.
Cheers Goog
Posted:
Fri Jun 15, 2018 11:46 am
by Myles
Mash have you ever considered a slush puppy machine?
Posted:
Fri Jun 15, 2018 1:02 pm
by Goog
I have a slush puppy machine, it’s great in the summer. Add a bottle or two of vodka to the mix and your all set. Just have to keep the kids away from it lol.
Posted:
Fri Jun 15, 2018 2:50 pm
by Myles
Drum with agitator, with freezer coils or ice and salt. This could be a real option.
Think over sized ice cream maker. As kids we used to hand churn ice cream that was cooled with ice and salt.
Posted:
Fri Jun 15, 2018 7:02 pm
I have to say I do all my washes this way saves an enormous amount of time, not sure the slushy will freeze it hard enough.
I freeze it till solid and then invert it over a bucket for 60 mins or so.
Posted:
Sat Jun 16, 2018 4:49 am
by Goog
Ours is a stir and coil machine for use in the canteen we run, no good for stripping as if you turned off the stirrer it would
freeze it solid but you won’t be able to get it out.
dinks only I think
Posted:
Sat Jun 16, 2018 5:16 am
by Myles
was thinking you might get easier separation from a slush compared to a solid block. The only time I tried this I put the wash in freezer bags and not in 1 solid block.
Posted:
Sat Jun 16, 2018 6:55 am
Not sure it could be easier but it is a patience thing. Takes longer than you think to freeze solid. Sometimes it does "polo".
It comes out easy enough, I wait about an hour and test/taste the drippings.
My freezer is -15c (any colder is unnecessary - for anything)
Expect to get 10-12l out @ 30% ish.
Posted:
Sat Jun 16, 2018 6:59 am
Myles wrote:was thinking you might get easier separation from a slush compared to a solid block. The only time I tried this I put the wash in freezer bags and not in 1 solid block.
All that said....
How does a slushy machine create the particles.. Are they frosted sugar crystals or would it do the same with just water?
Posted:
Sat Jun 16, 2018 12:15 pm
by Goog
We mix up a base of an apple juice solution like cordial and water, when added to the machine it freezes the water and not the solution so you are left with little ice drops in the liquid. As long as you keep the agitation going it doesn’t freeze solid. Stop the stirrer and it turns into a solid block of ice.
Posted:
Sat Jun 16, 2018 10:48 pm
Never freeze stripped but I used to make apple jack, back along.
That always seemed painless.
Posted:
Sun Jun 17, 2018 7:06 am
Goog wrote:We mix up a base of an apple juice solution like cordial and water, when added to the machine it freezes the water and not the solution so you are left with little ice drops in the liquid. As long as you keep the agitation going it doesn’t freeze solid. Stop the stirrer and it turns into a solid block of ice.
IF you emptied it out in the sieve - what would run though? Trying to get my head around stage 2.
It would be worth a test. But it does sound messier than turning the bucket upside down.
Posted:
Sun Jun 17, 2018 10:46 am
by Goog
Mash wrote:IF you emptied it out in the sieve - what would run though? Trying to get my head around stage 2.
Got me thinking now, I think it could work if you drained it through a sieve but not sure if it would
freeze enough of the water. Could be worth a trial if I can get the missus to let me in her canteen during the season break.
Posted:
Sun Jun 17, 2018 10:14 pm
Water freezes, Ethanol doesn't in a domestic freezer.
I am struggling to to see where this discussion is going.
Do it/try it or don't.
