Thought i'd update on this. I want to try fathom out where i went wrong. Here's where we are now: I went away for the bank hols weekend ,before i went it was looking like this, and still fermenting (bubbles coming though airlock)..........
I've racked it off tonight, and its looking like this:
I'm asking can i just make sure this is degassed properly and run it through , or do i need to make it clear first ?
Now to try fathom out where i went wrong as its taken 8 weeks or more for this
wash. Instructions say (roughly) 24 degrees for a fortnight ferment, 20 degrees for a three week ferment. I knew i might not quite make 20 degrees without my heater and insulation on the FV, so i expected a bit longer. I was concious of the instruction to not let the temp fall so i pitched low, 20 degrees. With hindsight i should of pitched higher and used an insulation jacket i think. Around the time i started this we also had the "beast from the east" so that didn't help. Over this same time period i've had no problem making lots of wine, difference (to me anyway) is the wine takes an extra few days without heater, as opposed to quite a few extra weeks with my
wash. Ok based on experience of one
wash. I've only ever done SS turbo washes before.
On the plus side its a very cheap
wash to make, and from tasting it its not unpleasant at all, its like a non descript dry wine. I've got my lentils for my next
wash, i'm not put off using the
Kale recipie i just want to try something different.
My next
wash i will pitch at a higher temp i think, and also use a bit less sugar. I don't mind losing a bit of volume if it makes it quicker. 3 weeks would be fine for me, but 8 weeks is just too long and i don't have space to sore that many FV's to keep me going like that. Any feedback appreciated, cheers.
