Re: First proper run .. Questions
I just completed a Heads only run, after dilution I had 45lt @ 25%ABV (very low ABV for better separation in this case)
My Heads runs are made up of collected Heads from multiple Spirit runs from my Pot Still, with the Fores having been dumped on the original runs - that's just my way of doing it
The first thing to remember about a Heads Only run is that there's going to be quite a lot of Heads produced and smearing is unavoidable. I simply dump the first 5lt - no questions - no smelling - no tasting
The next litre or so is collected in 200ml batches and each is tested on the fly. When I reach the one with hardly detectable traces of the Heads I switch to 750ml collections until it gets down to 50%ABV
Remember, there are NO Tails in a Heads Only run. As the ABV drops the output gets too slow to bother with as the boiler churns out more and more water with the ever decreasing volume of Ethanol.
At the end of the run I had collected 8lt of clean spirit with a batch ABV of 69%. I'd call that a result and a 'Heads-up' about doing Heads Runs
But, many here have been at this a long time now and while I know I could squeeze another couple of litres out of my
