VodkaStar and the amount of suger
Postby Luckyshot » Mon Mar 03, 2014 8:40 am
I have been trying to find some info on the amount of sugar to use with VS. At the moment I use 6k of sugar, but some folks use 5k.
Whats the advantages using 5k over 6k? I have looked on this forum but cant seem to find it, point me in the right direction somebody!
Regards Lucky.
Luckyshot
Stills: Air Still & T500
Re: VodkaStar and the amount of suger
Postby YHB » Mon Mar 03, 2014 9:20 am
And some use 4kg and some use only half the Vodka Star per wash and some..............
The theory goes like this.
The package that the VS comes in contains a particular strain of yeast that is tolerant to high levels of Alcohol and nutrients that will support the yeast while they are breathing the large amounts of sugar that it takes to make lots of alcohol.
So you can use lots of sugar and get lots of alcohol, but you also get tastes and the higher the amount of alcohol the more undesirable tastes there are. People often refer to this as "stressing the yeast" I do not know if the yeast actually get stressed but it seems a good analogy. When we get stressed we sweat get upset stomachs and smell bad, so why should yeast be different.
So to avoid the yeasts having to work so hard and getting stressed out, people reduce the amount of sugar, if you reduce the amount of sugar then you don't need as much nutrients.
It's your call and your process, if you distil twice and run the finished spirits through a carbon filter then you will get away with higher sugar and nutrient levels.
What works for some may not work for you, try it and see.
Personally I use the lower levels of sugar that you quote and with VS I find that a lower temperature ferment is the best way of avoiding the off tastes that we are talking about.
Postby Luckyshot » Mon Mar 03, 2014 12:33 pm
Thanks Brian,I think I will try 5k,if iam not mistaken Alcotec used to recommend 5.5k of sugar then upped it to 6k for some reason?
Regards Lucky.
Luckyshot
Postby John51 » Mon Mar 03, 2014 6:04 pm
I much prefer lower temperature ferments. I keep meaning to get a good stock of product so I can avoid doing washes during the summer but it never happens. :)
John51
Postby Easydrinker » Mon Mar 03, 2014 11:22 pm
Nice post Brian.
You said it all,I think.
I'll move along.
