Freeze Stripping
Re: Freeze Stripping
Postby Mash » Tue Jun 12, 2018 6:43 am
Are many people freeze stripping?
Postby Goog » Tue Jun 12, 2018 10:00 am
I had a go at it with 10lts of TPW last week as an experiment, after I thawed out my bid orange icy pole I ended up going with a strip run. I am not ruling out having another go but might wait until I got the process of stripping and spirit runs down a bit more first. Still learning and trying so all good.
Cheers Goog
SUCH IS LIFE.
Goog
Stills: Air still, 50lt keg
Postby Myles » Fri Jun 15, 2018 11:46 am
Mash have you ever considered a slush puppy machine?
Postby Goog » Fri Jun 15, 2018 1:02 pm
I have a slush puppy machine, it’s great in the summer. Add a bottle or two of vodka to the mix and your all set. Just have to keep the kids away from it lol.
SUCH IS LIFE.
Goog
Postby Myles » Fri Jun 15, 2018 2:50 pm
Drum with agitator, with freezer coils or ice and salt. This could be a real option.
Think over sized ice cream maker. As kids we used to hand churn ice cream that was cooled with ice and salt.
Postby Mash » Fri Jun 15, 2018 7:02 pm
I have to say I do all my washes this way saves an enormous amount of time, not sure the slushy will freeze it hard enough.
I freeze it till solid and then invert it over a bucket for 60 mins or so.
Postby Goog » Sat Jun 16, 2018 4:49 am
Ours is a stir and coil machine for use in the canteen we run, no good for stripping as if you turned off the stirrer it would freeze it solid but you won’t be able to get it out. :-\ dinks only I think
SUCH IS LIFE.
Goog
Postby Myles » Sat Jun 16, 2018 5:16 am
was thinking you might get easier separation from a slush compared to a solid block. The only time I tried this I put the wash in freezer bags and not in 1 solid block.
Postby Mash » Sat Jun 16, 2018 6:55 am
Not sure it could be easier but it is a patience thing. Takes longer than you think to freeze solid. Sometimes it does "polo".
It comes out easy enough, I wait about an hour and test/taste the drippings.
My freezer is -15c (any colder is unnecessary - for anything)
Expect to get 10-12l out @ 30% ish.
Postby Mash » Sat Jun 16, 2018 6:59 am
Myles wrote:was thinking you might get easier separation from a slush compared to a solid block. The only time I tried this I put the wash in freezer bags and not in 1 solid block.
All that said....
How does a slushy machine create the particles.. Are they frosted sugar crystals or would it do the same with just water?
Postby Goog » Sat Jun 16, 2018 12:15 pm
We mix up a base of an apple juice solution like cordial and water, when added to the machine it freezes the water and not the solution so you are left with little ice drops in the liquid. As long as you keep the agitation going it doesn’t freeze solid. Stop the stirrer and it turns into a solid block of ice.
SUCH IS LIFE.
Goog
Postby Easydrinker » Sat Jun 16, 2018 10:48 pm
Never freeze stripped but I used to make apple jack, back along.
That always seemed painless.
Postby Mash » Sun Jun 17, 2018 7:06 am
Goog wrote:We mix up a base of an apple juice solution like cordial and water, when added to the machine it freezes the water and not the solution so you are left with little ice drops in the liquid. As long as you keep the agitation going it doesn’t freeze solid. Stop the stirrer and it turns into a solid block of ice.
IF you emptied it out in the sieve - what would run though? Trying to get my head around stage 2.
It would be worth a test. But it does sound messier than turning the bucket upside down.
Postby Goog » Sun Jun 17, 2018 10:46 am
Mash wrote:IF you emptied it out in the sieve - what would run though? Trying to get my head around stage 2.
Got me thinking now, I think it could work if you drained it through a sieve but not sure if it would freeze enough of the water. Could be worth a trial if I can get the missus to let me in her canteen during the season break.
SUCH IS LIFE.
Goog
Postby Easydrinker » Sun Jun 17, 2018 10:14 pm
Water freezes, Ethanol doesn't in a domestic freezer.
I am struggling to to see where this discussion is going.
Do it/try it or don't. 8)
Return to Distillation
Users browsing this forum: No registered users and 4 guests
In total there are 4 users online :: 0 registered, 0 hidden and 4 guests (based on users active over the past 5 minutes)
