Heater
Heater
Are aquarium heaters safe to use and worth it ? I know there not that expensive and keeps everything nice and same temp, question is more if it's safe and do people use the,, thanks
- Stills: Airstill
Re: Heater
Lots of us have used them in the past, but in my opinion external heaters such as pads, belts etc. are better.
vino-tinto - Senior Distiller
Re: Heater
100% What Vino said.
Pads and perhaps a jacket / fleece cover
Pads and perhaps a jacket / fleece coveremail still_smart@yahoo.com and stay in touch. More details viewtopic.php?f=1&t=4947
Re: Heater
Not too sure how true it is but read on a forum a few years ago that the belts were too hot, especially on demijohns.
Never used one myself but do use one of the two aquarium heaters I have. Also got one of the Electrim 75 immersion heaters which I occasionally use as well. Picked up two brand new for a tenner secondhand a couple of years ago.
Never had a problem with any of them and always check with a stick thermometer to make sure that are working ok and at the correct temperature. For how old all three are they are all very accurate.
Chubbs - Regular
- Stills: Air Still & T500
Re: Heater
I use aquarium heaters only, as my brew heat source.
One or two have died in service over the years.
I keep a bunch of backups, as to me they are are so simple and inexpensive.
For most of the ferment the Yeasties provide their own heat anyway.
I do check them all for actual temp. against stated temp. in a jug of water.
And label accordingly.
Re: Heater
After problems with other heaters I converted to this type, and now wouldn't use anything else.
I put the heater in the wash while it is still warm and leave it in the wash to cool down before removing it at the end of the run, this reduces stress on the element.
Pyro - Experienced Distiller
- Stills: Twin Airstills,
Re: Heater
Ahh ok so both depending who you ask, but by the sounds of it everyone would recommend at least one or other I stead of neither ? I'm fine with demijohns but when you have a few 25l buckets it's hard to keep somewhere warm, thanks
- Stills: Airstill
Re: Heater
Unless you are living in the Tropics, some form of heat will help reduce your ferment times.
How you choose to keep your babies warm is your choice.
Re: Heater
Easydrinker wrote:Unless you are living in the Tropics.........
Which brings a whole heap of new problems. There are numerous solutions tho'....
Re: Heater
Easydrinker wrote:... some form of heat will help reduce your ferment times.
And improve the product
Re: Heater
And some form of cooling will further reduce the workload.
Freeze strpping, for those with the ability/capacity should work well.
There are indeed many ways to skin this particular rabbit.
Experimentation......
Become lazy, like me and several others here, and find someting that works.
Or constantly strive for quicker, cheaper, faster.
We are all correct. Because we are all content.
Here endeth the sermon for today.
Re: Heater
What temperature is a favourite?
Curmudgeon - Master Distiller
- Stills: pot head
Re: Heater
I use almost excusively Allinson's bread yeast.
They seem to be happiest at 30°C.
At least in my brew room.
Re: Heater
Easydrinker wrote:I use almost excusively Allinson's bread yeast.
Thankyou Sir. I have been brewing at 21 and will increase on that.
- Stills: pot head
Re: Heater
From the depths of memory I recall temps of 21C in the days that I nursed beers and wines.
These days I only make harder stuff.
30C works for me, I hope it does for you.
