Some finishing touches done yesterday.
Soldered in a thermowell
Stuck on a thermometer
Blinged up the parrot
And did a final cleaning run as id done a bit of soldering and repacked with new scrubbers that got a good wash in the dishwasher first.
Charged the boiler with 35L of 11% wash, and about 3L of 70% junkahol, (so about 15-16%)
Managed to get about 94% reading on the parrot using a 70-100 narrow range alcometer, but the liquid was about 12oC so it may have been higher ABV as the alcometer is calibrated for 20oC, I have no problem believing it will do azeotrope if charged with low wines.
I'm waiting on a couple of 6mm fuel line valves to let me bypass the tube going through the parrot to prevent overcooling of the distillate in future. I could have just changed the plumbing yesterday, but it was just a cleaning run.
I'm also not sure how often I will actually run with the parrot, it does hold quite a bit of liquid, so I've bent another bit of 22mm that I can screw on to the fitting to use a spout if I find I get smearing (shouldn't really be pulling anything but hearts off down the product arm any way)
I found I was able to adjust the reflux and increase the output quite finely and dialed in 93,92 and 90 ABV - so looks like this might be good for things like white rum, or doing a grain vodka where you want to preserve some of the flavour.
I then stuck it into pot still mode and stripped the rest of the alcohol out.
Don't think I'll actually use this still as a pot still, as its just so cumbersome to get onto the boiler. I'd have to have a boiler that I could fully drain and clean in place with the still head still attached to make that something that wouldn't turn into a huge PITA after the novelty wore off.
