fuselex Brand filters ( I\'m the manufacturer)
• Page 1 of 3 • 1, 2, 3
Hello to all , Ive just found a thread relating to my FUSELEX filters. There was some feedback about pit corrosion which i would like to clarify. Yes,in seven years I\'ve had a few returned, which are replaced free of charge. It should be noted that it will ONLY happen if the crystalline structure of the steel has imperfections,( global failure rates of SS is at 5% for industrial applications),this style filter is a miniature version of a commercial situation. Suffice to say , if it didn\'t happen within 1,2, or 3 uses, it never will happen. the FUSELEX nano and the master version are intend to replace the use of plastic, which can be toxic if used incorrectly, i.e, some alternative filters use a water filter style carbon block and ceramic cartridge. Some use Butyle rubber bungs, some use PP. Some even have polycarbonate components, and god forbid \"bisphenol A\" which is used as a plasticizer for molding plastic and is being systematically banned in food containers etc, as its a known carcinogen, even leaching out in tap water. I designed the FUSELEX filters to allow freedom from being locked into buying a block cartridge. bagged GAC is much cheaper for the consumer.
If any keen distillers are looking for something , I can arrange for shipping to the UK.
Hope this clears up any questions about the brand, and thanks for reading.
Craig
Craig
Craig - Newcomer
I have used the full size FUSELEX filter since I started this hobby, never had a problem.
Where do you hail from Craig??
Andy - Senior Distiller
hi craig, i for one am very interested in your filter. how much would you be charging delivered to the uk? don\'t suppose you have an ebay shop? (only ask as i buy internationally on ebay already)
cheers, hoppin
cheers, hoppin
hoppinmad - Experienced Distiller
Hi Craig - thanks for joining - it was me that contacted you yesterday regarding these filters and importing them to the UK - feel free to get in touch with any further info. Cheers!
Jimmy - Site Owner
Oh, and for those who are curious - I was intending to see about putting together a batch and getting them shipped over to distribute through here - what do you guys think, any interest?
Jimmy - Site Owner
Talk about coincidences I bought one the other day, they are sold at Leyland homebrew and Stockport homebrew.
http://www.thebrewshop.com/index1.html
http://www.leylandhomebrew.com/cat113_1.htm
It was the larger ones I was looking at, nobody seems to sell those here...?
Jimmy - Site Owner
it will be interesting to see what the delivered price is especially considering the essencia filter and the small fuselex already available. i hope they are affordable as they are very sexy looking
hoppin
hoppin
Craig, thanks for the info.
The nano seems just what I\'m looking for. Space/price restrictions etc.
@bluecap; what\'s your views of it.
Electrif
Electrif
Whoever said nothing is impossible never tried slamming a revolving door....
Electrif - Regular
- Stills: T500, Airstill
Ok my view on the nano, I like it even though it is only the small one, it filtered 11 litres of a pretty clean spirit to perfection, its easier to use than the Z filter and its huge advantage is after unscrewing both ends and pouring dry carbon in, with a funnel you can pour boiling water from a kettle very rapid through it to clean and activate it which adds considerably to the purification process but beware being stainless steal the whole unit gets red hot. The instructions say to let it flow at 2 drops a second this took about 4 days so don’t be in a rush for it.
I have thought about on of these, makes it easier to justify the cost to the misses. I assume you use it like the Z between two pales. Dose it come with the wall mounted brackets as well.
BundyRed - Regular
Yes it works just the same in principle as the Z filter (two pales) and does have a small bracket but I just left it hanging.
Thanks bluecap
Ditto, now where\'s the butter.
Electrif - Regular
I should just point out that you don’t get the pales with the filter, it is just the filter.
Yeh, I thought that. BTW what are the micro filters, are they disposable & how many do you get.
Electrif - Regular
