\"ss top shelf\" vrs \"ss classic\"
Different methods and recipes
Postby foRUM warrior » Thu Jun 10, 2010 11:03 pm
apart from £2 difference a go (or there about) what is the difference between the ss classic and ss top shelf flavouring's??
foRUM warrior
Postby marc83 » Fri Jun 11, 2010 12:20 am
There is a bit more essence in the classic range,two 36ml sachets,compared to a 50ml bottle in the top shelf.
I guess the difference is in the taste.how much different im not sure.
marc83
Postby hoppinmad » Fri Jun 11, 2010 12:47 am
i personaly find the classic range a far superior flavouring and definitely worth the little extra,
cheers, hoppin
hoppinmad
Postby Phantom » Fri Jun 11, 2010 1:47 am
I always allow for the cost of the classic ones. Taste-wise, they seem a lot nicer. Whether that\'s because of the actual amounts you get or not I don\'t know - but they just taste better.....
Postby trelliS » Fri Jun 11, 2010 7:17 pm
Im with Phantom and Hoppin on this one the classic range is more of a sipper and the top shelf is for throwing down your neck or experimenting with
trelliS
Stills: Air still and T500
Postby foRUM warrior » Fri Jun 11, 2010 9:30 pm
thanks for your input guys i appriciate it :)
foRUM warrior
Postby marc83 » Sat Jun 12, 2010 3:29 pm
I bought a SS classic tennessee bourbon pack today,and found it has two 27ml sachets,when previously i had used a SS classic american bourbon essence with two 36ml sachets...interesting.
Anyway,i mixed one sachet with 1125ml of spirit and it looks very light in colour compared to just about any of the bourbon essences i have used,if not all.I have put some spirits unlimited JD chips in with it,might darken it a tad,and see how it turns out.
marc83
Postby foRUM warrior » Sat Jun 12, 2010 6:21 pm
just so you all know apparently the ss classic range is changing, rather than flavour 1125ml of spirit, the new pack size is designed for 1L ...... apparently they are dropping the price to keep it all in ratio.
foRUM warrior
Postby BundyRed » Tue Jun 15, 2010 4:41 am
are all 1125 bottles going to 1000ml bottles world wide.
BundyRed
Postby marc83 » Tue Jun 15, 2010 11:30 am
That sounds like a good idea.have way more 1L bottles than 1125s these days.
marc83
Postby trelliS » Fri Jun 18, 2010 2:25 am
That will be a shame if they do .... i often use the left over part bottle for mixing with something else or just experimenting with.eg part bottle kentucky bourbon same of scotch malt and 40ml of cafe maria is a really nice warming mix on a winters day when fishing.
trelliS
Postby foRUM warrior » Fri Jun 18, 2010 4:52 am
yep they are 1l size
foRUM warrior
Postby Ronbo » Tue Jul 20, 2010 5:29 pm
Hi All,
Just tried the SS Classic / Premium / Finest Reserve / Whisky.
32 mL sachet added to 1 Litre of 50% double distilled.
Left it in the bottle for a couple of weeks first.
I don\'t claim to be a \'Malt expert\' but I love \'Glen Livet\'
This stuff is a slightly different flavour, but I can\'t fault it.
9/10
Ciao.
Ronbo
Postby Ronbo » Tue Jul 20, 2010 11:58 pm
Hi All,
Just realised what might transform this to 10/10.
Add the 32mL to just 40% double distilled, 1 Litre.
Will try this next time and leave for a month!
Might be a lot smoother.
Ciao.
Ronbo
Postby freelancement » Wed Jul 21, 2010 5:02 am
Alright .... going from what ive heard, the SS Classic range are actually infusers requiring a minimum of a week to chemically infuse with the alco, where as the SS Top Shelf range are food flavours and will be ready to drink straight away after mixing. This is noticable with the gin flavours. Now, again from memory they are slit into 2 packs for the reason that they have an alcohol trace in the packs to help kick start the process and as a result the two packs are more designed to get around certian legal issues and having to say that they have traces.
SS also have a 1L range for the SS Turbo Air Still, as the still only produces 1L @ 40% per distill, so they released a range to match.
comparing this to the Essencia range, I am of the understanding that the essecia range is completely infusing but doesnt have the alco trace, requiring longer maturity.
Should note that the volume of the bottle of packet doesnt imply that there is more flavouring, its just more \'filler\' ..... but that said if you try the SS origianl range which makes 5L per 50ml bottle, the Classic range kills it for dead
Food for thought
freelancement
