Yeast Experiment
Yeast Experiment
Postby gaza the instructor » Fri Jun 10, 2016 4:36 pm
Just set 3 batches of BT rum.
Standard wash for me, 2kg BT and 4.5kg
demarara sugar. Had two Coopra Rum Yeast
in stock so used them, other one 50g
bakers yeast. All started between
1092 and 1094 OG, all at about 25C.
That was yesterday, today all three
singing away to that bubbly tune.
Will post findings at end of fermentation.
Re: Yeast Experiment
Postby Mash » Sat Jun 11, 2016 8:02 am
The taste as a wine (before strip) will be different. But it will be interesting even more to see the difference after the spirit run.
Postby gaza the instructor » Sat Jun 11, 2016 2:52 pm
Hi Mash, probably wont know that one,
cause all 3 washes striped then combined
for one big spirit run.
On day 3 all bubbling nicely, the smell
is fantastic :) :)
Not quite sure if the rum yeast is a turbo
or not. Bakers given vit C, dead cells and
Epsom salts for nutrients.
Should produce a nice rum for my birthday. :)
Postby Mash » Sun Jun 12, 2016 5:47 am
Sorry we have disconnected somehow. If they are still bubbling, I thought you could taste them before stripping?
PS I don't think of Epson salt as a nutrient, more a water treatment.
Postby gaza the instructor » Sun Jun 12, 2016 6:17 am
It is mentioned quite a lot with
bakers yeast,which I have only started
experimenting with.
So by that you mean like a PH buffer??
The washes are still fermenting like
mad, there is something about BT which
just makes everything explode into
action.
Postby Mash » Sun Jun 12, 2016 6:39 am
I am watching this post 'cos I think your recipe could make a good base for kraken. BT and molasses are both stuffed with nutrients that yeast like. They should always take off well. 8)
Postby Mash » Sun Jun 12, 2016 6:48 am
Epsom salts are magnesium which is generally used to assist with lowering PH. But also a trace element for yeast...but that shouldn't be lacking in your wash.
I did a bit of research & experimentation with ph and have decided (for me) it ain't broke so I don't need to fix it until it is broke :)
Postby gaza the instructor » Sun Jun 12, 2016 11:16 am
I read somewhere that if your kettle
furrs up PH should not be a problem.
We have hard water here, kettle is descaled
once a month at least.
Have done this one before it does make a
very tasty rum Mash. :) :)
Postby Mash » Sun Jun 12, 2016 11:40 am
Might have to give it a go. In between a few beer runs.
Same here my water is hard as proverbial nails
Postby gaza the instructor » Sun Jun 12, 2016 7:43 pm
Great for bitter none better than
London water :)
Postby gaza the instructor » Mon Jun 13, 2016 9:34 am
Day 4 fermentation on rum yeast slowed
but bakers still active, will leave for another
day and check gravities.
Postby Easydrinker » Mon Jun 13, 2016 11:11 pm
Mash wrote:Epsom salts are magnesium which is generally used to assist with lowering PH. But also a trace element for yeast...but that shouldn't be lacking in your wash.
I routinely add a teaspoon of Magnesium Sulphate (Epsom Salts) to my neutral brews, along with a teaspoon of DAP, even when adding minced raisins as a food source to complement the lentils or split peas.
All are cheap as chips.
I do not have an issue with starting Ph, but for the next 3 days throw in two teaspoons of Bicarbonate of Soda.
Day 5 or 6 it has stopped fermenting and it is racked off.
Depending upon available time it is then racked into the still for a strip,anywhere from day 7.
Postby Mash » Tue Jun 14, 2016 12:24 pm
Different folks. Different strokes. Different water.
I think I'm very lucky with my water.
Postby gaza the instructor » Wed Jun 15, 2016 7:47 pm
Day 6 bins 1&2 (rum yeast) down to
1000 and 1002 no activity bin 3 (bakers)
still 1010 bubbling once a min.
racking other 2 will run fri & sat.
Yield on 1&2 about 12% happy with that.
Mash the smell is yummm!!!
I love rum :) :) :)
Postby Easydrinker » Wed Jun 15, 2016 11:22 pm
Nothing wrong with my water.
Simple optimisation is all.
