Condenser construction
Postby Devon » Wed Oct 28, 2015 3:24 pm
Does anyone know of someone who could build me a coil to fit in a 54mm pipe? For a bokakob still? I can't find anyone who I usually use for my brewery to make one small enough but still suit the parameters required for operation. Usually I'd make the coil, but i want to outsource because I would just waste copper pipe attempting to Make one
Devon
Re: Condenser construction
Postby Magnu420 » Wed Oct 28, 2015 3:45 pm
Its easy to make a double coil it took me 3 attempts to make my coil
I think it cost me about £30 for 25mts of 6mm soft copper tubing from jtm
Plumbing search on here also theres pdf download called winding a coil again
Use the search
I think anavrin had some for sale
Magnu420
Stills: Airstill + half boka
Postby vino-tinto » Wed Oct 28, 2015 5:09 pm
The easiest way to make a coil.
Get some 6mm pipe from JTM, fill the coil with water and put it in the freezer. Whilst it's still frozen wrap it around some 40mm waste pipe. It will fit inside 52mm.
vino-tinto
Postby Mash » Wed Oct 28, 2015 5:49 pm
Is it worth filling it with sand?
Postby vino-tinto » Wed Oct 28, 2015 6:03 pm
Mashy wrote:Is it worth filling it with sand?
It's easier with water, you would need pressure to force sand around a coil.
Plus when it thaws out it runs out on it's own.
vino-tinto
Postby Magnu420 » Wed Oct 28, 2015 6:33 pm
You gotta have a tall freezer to freeze about 2.5m length of copper
Magnu420
Postby vino-tinto » Wed Oct 28, 2015 6:40 pm
Magnu420 wrote:You gotta have a tall freezer to freeze about 2.5m length of copper
It comes in 10 meter coils, about 50cm in diameter.
vino-tinto
Postby chill » Wed Oct 28, 2015 7:11 pm
That sounds like a smart way to wind a coil!
Postby Devon » Wed Oct 28, 2015 9:06 pm
My freezer is tiny, so no chance of freezing it. I will take a look at this guide for winding coils, but im still concerned I will kink it or something like that.
Devon
Postby Easydrinker » Thu Oct 29, 2015 12:03 am
vino-tinto wrote:The easiest way to make a coil.
That sounds like pure genius! If not all your own work, share in the Kudos for putting it out there.
I knew of filling with sand, never would have considered freezing water inside.
Has to be much easier than annealing and waving gas torching around?
Postby Mash » Thu Oct 29, 2015 6:33 am
Very good idea.
Postby vino-tinto » Thu Oct 29, 2015 6:52 am
I made my double condenser coil by freezing it as I described and wrapping around some 22mm copper pipe, then when I got 12 coils I slid a 40mm waste pipe over the top and wrapped it around that going in the opposite direction.
vino-tinto
Postby Mash » Thu Oct 29, 2015 9:07 am
That certainly is proof - if ever it was needed. Well done.
Postby Icefever » Thu Oct 29, 2015 7:01 pm
Mash has changed his avatar......why?????????????? :D :D
Postby Mash » Thu Oct 29, 2015 9:57 pm
I have a cunning plan
Users browsing this forum: Google Adsense [Bot], Maker and 3 guests
In total there are 5 users online :: 2 registered, 0 hidden and 3 guests (based on users active over the past 5 minutes)
