Liquidised Sweetcorn Sugarhead
Postby Easydrinker » Thu Oct 24, 2013 1:00 am
I have read various posts on here about folk wanting to make corn washes for American style whiskeys,how difficult flaked maize is etc.
I have looked at UJSSM,- why learn to walk when you can try to fly?
Why fall flat on your face,when you can land on your head from a great height?
I have just done several mashes using frozen sweetcorn,liquidised,for maximum taste/possible conversion,as I also wanted to see how much difference amylase enzyme makes to the brew,- should produce more alcohol,but strip some of the corn flavour.
At this point,being a long time user of Turbo yeast,I decided to put it head to head with bread yeast.
Four mashes,two yeasts then.
Redneck procedure:
Defrost corn,and in this instance,leave sitting around for two days.
Put in food processor/blender,with a little water.
Liquidise,do this several times ; I used just over 8Kg sweetcorn.
Put half the result in boiler,heat to 66°C ,add amylase enzyme,hold it there for an hour,give occasional stir,and as it slowly cools.
Make four mashes of just under 24 litre,two with liquidised corn; two with liquidised and amylased corn.
One of each with half a sachet of turbo,and one of each with half a tub of bread yeast=62.5g.
All four had 5Kg sugar added.
Didn't bother with hydrometer reading from sweetcorn soup,there's too much suspended solid,and a floating head of husk.Wait for strip run to assess amount of ethanol produced.
Hope it is as tasty as expected when spirit run happens,the smell from the soup is lovely.
Leave husks floating,as under cold Northern skies it looked like buckets of sunshine,in the bread yeast fermenters they sank towards the end .
To my amazement,it was the bread yeast that took off first,in both the "cooked" and uncooked mashes,but then was overtaken by the turbo,which by day 5 was ready to rack,at .990.
Ferment temps were around 22-25°C.
The Allinsons yeast took 14 days longer,even with later applied modest heat.(TBH,given my new experience of hydrating and growing yeast up,I think this time could be dramatically reduced)
A whole week of settling saw all the washes clear the top 3" only.I decided not to bother with fining.
The smell from all racked and strained washes was well sour.
About 3 -3.5 litres of lost sludge in the turbo fermenters,almost 5 in the unamylased bread yeast,and 3.5 in the amylased bread yeast wash.
I racked into the boiler.leaving the worst of the sludge behind. Individually of course,for strips and spirit runs; this was to be a trial by alcohol and taste.
I wander here from fermenting to distilling,forgive me.
Approx 24 litres mash became approx 20.5 Lt in the boiler.
By far the murkiest washes that I have ever distilled. I simply turned the power down to 1500W for the uneventful strips to 5%,and then four spirit runs,at 700W.
Yes,a lot of work,and posssibly a wasteful exercise.
There are differences in the raw spirit.A little more alcohol,10% ish from the amylased corn,and certainly less flavour.I can't decide in the current state if any one of them is much better than another,certainly some interesting tastes in there.Sure beats a sugar wash for interest,and only doubled the cost,still peanuts (anyone tried a peanut wash?).Time to put them to sleep with some barrel chunks,and come back later.
Oh well, it keeps me off the streets..
Re: Liquidised Sweetcorn Sugarhead
Postby Almanac » Thu Oct 24, 2013 9:05 am
I tried various uses of sweetcorn in mashing and ferments and was too embarrassed to post details here ::) not the same thing as using raw corn and converting the starch ::) but all experiments are valid even if not very useful ;)
Postby Easydrinker » Thu Oct 24, 2013 10:18 pm
I have reached a point in my life that I am very rarely embarrassed. I allow the world to see me warts and all.
My experiment did not produce bad spirit; my problem is that there was much less difference in the four products than I expected.
Having nuked one of the samples today I am sitting here sipping it this evening ,while stripping a sugar wash.It tastes much better than this sugar wash will.
I have not given up on liquidised sweetcorn; I think it has lots of flavour,whilst producing quite a lot of waste sludge.Might try it with LME next. I can see that just tipping sweetcorn into a wash will not add much.
Postby FullySilenced » Sat Nov 09, 2013 5:14 pm
Put the blended corn in a cotton/linen bag then squeeze all the good stuff out after the ferment... very little loss that way... but still messy
happy stillin
FS
FullySilenced
Stills: 2 Still Dragon's
Postby Easydrinker » Sat Nov 16, 2013 1:14 am
I did put the sludge through a fine sieve; might try an old pillow case next time.
Coming back to taste it again tonight,it really isn't bad,quite good in fact,lots of taste and flavour,even at this late hour.
Probably what I would expect from a Southern US style whiskey.
For sure it can be improved upon.
It has to wait though.,
That sack of heavily peated malt barley sits looking at me,almost crying out, "USE ME"
Some messy work ahead,some happy results anticipated...
Ain't life grand!
