Parrot ?
Info specific to the T500
Parrot ?
Postby ninja_geezer » Wed Apr 11, 2018 10:27 pm
ninja_geezer
Re: Parrot ?
Postby Mash » Thu Apr 12, 2018 6:13 am
Wow.
That seems expensive for what is quite a straightforward build.
You would also need a spirit hydrometer.
Re: Parrot ?
Postby Anavrin » Thu Apr 12, 2018 8:31 am
Perhaps im missing something, but it says at the bottom of the description, that it’s not suitable for the alembic still!
Re: Parrot ?
Postby ninja_geezer » Thu Apr 12, 2018 4:06 pm
Mash wrote:Wow.
got 2 ;)
ninja_geezer
Re: Parrot ?
Postby ninja_geezer » Thu Apr 12, 2018 4:08 pm
Anavrin wrote:Perhaps im missing something, but it says at the bottom of the description, that it’s not suitable for the alembic still!
I do believe that is because its designed to fit directly onto the outlet of the condenser column and not on the Alembic output tube that's all.
ninja_geezer
Re: Parrot ?
Postby gaza the instructor » Thu Apr 12, 2018 7:23 pm
Can use it in either if you make a wooden base for it.
I think you can do better if you surf the thingy web.
Re: Parrot ?
Postby ninja_geezer » Thu Apr 12, 2018 7:43 pm
gaza the instructor wrote:Can use it in either if you make a wooden base for it.
Cheers gazza open to any links you may have buddy ;)
ninja_geezer
Re: Parrot ?
Postby ninja_geezer » Tue May 01, 2018 11:31 pm
My buddy just made me this up whilst i was away..
All the bits i got from eBay except for 2 bits from local plumb shop .
The fancy spiral is just the 6mm pipe slowly wrapped around a wine bottle it took me 2 mins to do very easy ,then just got my buddy to get his blow lamp out (he is way better than me at stuff like that). ;D ;D
ninja_geezer
Re: Parrot ?
Postby Mash » Wed May 02, 2018 5:50 am
Nice one. Get your buddy to teach you to solder. It's a very rewarding and complimentary skill with this hobby.
Re: Parrot ?
Postby ninja_geezer » Wed May 02, 2018 9:35 am
Mash wrote:Nice one. Get your buddy to teach you to solder. It's a very rewarding and complimentary skill with this hobby.
Might just do that mash ;)
ninja_geezer
Re: Parrot ?
Postby H12rpo » Wed May 02, 2018 10:12 pm
ninja_geezer wrote:My buddy just made me this up whilst i was away..
That, Sir, is a thing of beauty !
H12rpo
Re: Parrot ?
Postby Easydrinker » Wed May 02, 2018 11:57 pm
Even better, it looks like a working tool.
Re: Parrot ?
Postby Brewhunter » Thu May 03, 2018 7:32 pm
That is a great looking parrot.
Brewhunter
Stills: T500 + Airstill
Re: Parrot ?
Postby gaza the instructor » Thu May 03, 2018 7:53 pm
At least it does not scream and swear at you
like my parrot.
Re: Parrot ?
Postby ninja_geezer » Wed May 09, 2018 6:57 pm
Easydrinker wrote:Even better, it looks like a working tool.
Works a treat .... ;)
ninja_geezer
Return to T500
Users browsing this forum: Baidu [Spider] and 1 guest
