Tbh frank, there is a couple of things that are different from previous times are:
1. I have sacked the heat plate now and use a fish tank heater, which held a consistent temp through the brewing stage which also helped with it finishing brewing quickly. I mention this as reading in previous posts it's mentioned that if it's not finished brewing it won't clear correctly.
2. It's really cold here at the moment so when its finished brewing, I degass then put outside, then next day degas again then bring in to settle. Then the next day I rack off to a new barrel then this went back outside again for a few days to clear.
I'm going to follow this again and see if I get the same results. Also now once it's degassed and into another barrel I can get the next one to start brewing. Which means instead of taking a month all in I'm getting nearly 4 litres every 2 weeks. This should give me chance to build a stock up.......maybe
